版权归原作者所有,如有侵权请联系删除
返回版块19.44 万条内容 · 661 人订阅
桥梁“裤衩梁”结构空间梁格计算,拓展你的思路!桥梁异形结构,如连续梁分叉部分, 常见由直线梁和曲线梁组成 , 根据路线走向以各种方式相结合 , 截面形式以箱梁居多。 其受力情况比较复杂,分析起来比较麻烦。 一般这样处理的:将分叉处增加腹板,这样活载的分布相对均匀些,然后按杆系进行平面计算。只是预应力钢束要分到增加的腹板中,或者再增加短束。活载的横向分布系数应大些。
只看楼主 我来说两句 抢板凳这种技术值得研究!
wxkfp2017.jimdo.com,xmkfp2017.jimdo.com,gykfp2017.jimdo.com,lzkfp2017.jimdo.com,kmkfp2017.jimdo.com,nckfp2017.jimdo.com,hfkfp2017.jimdo.com,tykfp2017.jimdo.com,wlmqkfp2017.jimdo.com,sjzkfp2017.jimdo.com,zzkfp2017.jimdo.com,fzkfp2017.jimdo.com,cckfp2017.jimdo.com,xakfp2017.jimdo.com,sykfp2017.jimdo.com,hebkfp2017.jimdo.com,whkfp2017.jimdo.com,cdkfp2017.jimdo.com,jnkfp2017.jimdo.com,cqkfp2017.jimdo.com,njkfp2017.jimdo.com,tjkfp2017.jimdo.com,szkfp2017.jimdo.com,gzkfp2017.jimdo.com,shkfp2017.jimdo.com,0871kfpcs.jimdo.com,0771kfpcs.jimdo.com,0791kfpcs.jimdo.com,0351kfpcs.jimdo.com,0591kfpcs.jimdo.com,027kfpcs.jimdo.com,0531kfpcs.jimdo.com,0311kfpcs.jimdo.com,0731kfpcs.jimdo.com,0431kfpcs.jimdo.com,024kfpcs.jimdo.com,029kfpcs.jimdo.com,023kfpcs.jimdo.com,025kfpcs.jimdo.com,0571kfpcs.jimdo.com,022kfpcs.jimdo.com,020kfpcs.jimdo.com,021kfpcs.jimdo.com.
