土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 我为自己设计的新农村房屋
我为自己设计的新农村房屋
发布于:2008-01-16 17:03:16 来自:建筑设计/居住建筑设计 [复制转发]
如下是我结合实际的土地设计的,我不是专业的设计,我是搞机械的,所以画得不好。望各位给点意见!谢谢!
全部回复(37 )
  • 田哥2018
    田哥2018 沙发
    很好很好很好很好
    2018-08-25 21:48:25
  • 洋儿
    洋儿 板凳
    可以可以可以可以
    2018-08-21 15:21:21
居住建筑设计
28.74 万条内容 · 423 人订阅
无比轻钢建筑介绍
Integra Shear Wall Design®Specifications & Installation of Integra Shear walls©1.0 SUBJECT For construction of Integra Shear Wall panels an assumption of fasteners used are “Buildex Fasteners” for application of Plywood/OSB Panel Integra Shear Walls and Integra Diaphragm panels, where “Buildex Fasteners” or other comparable fasteners are used to attach structural sheathing to Integra Steel Framing Members such as Integra Wall Studs, Integra Floor Joist or Integra roof framing members. All Integra members used in shear or diaphragm construction must have minimum yield strength of 33 ksi (228 kPa) and a minimum tensile strength of 52 ksi (359 kPa). Integra Steel joists for diaphragms must comply or be comparable with the Canadian NCBC code and must be suitable for the direct support of Integra floors and Integra roof decks. The fasteners used in Integra light steel framing are limited for use with diaphragms framed with cold-formed framing members and must comply or be comparable to, Division VII, Chapter 22, of the Canadian 1997 Uniform Building Code™ (UBC). Recognition of the fasteners for use with heavier steel, common to open-web steel joists referenced in Section 3, Division IX, Chapter 22, of the UBC, is beyond the scope of this Integra Manual.
