土木在线论坛 \ 人才招聘 \ 学生专栏 \ 建筑英语
建筑英语
发布于:2008-01-09 13:42:09 来自:人才招聘/学生专栏 [复制转发]
热源 heat source
平面位置的空间 space of planimetric position
密封性能 sealing performance
机房 machine room
节点 timing
专业 "profession or discipline 都可以,要根据上下文"
连体法兰 coupling flange
垂直井笼 vertical well cage
变风量 variable air rate
施工面展开 construction unfolds
违约行为 noncompliance
合同交底- contract presentation
管理承包商 Management Contractor party
工程量 work amount
实施的形象进度 progress of implementation
完工资料 as-built documentation
文整 clear-up
审核 review
汽车式起重机 Autocrane
深化图纸 deepen drawing
设备配置计划 equipment furnishment plan
结构预埋配合阶段 Structure pre-embedment assistance stage
精装修阶段 Fine fitment stage
工程施工阶段 Construction stage
工程竣工阶段 Completion stage
台钻 Bench drill
冲击钻 Churn drill
手电钻 Electric portable drill
砂轮切割机 Abrasive cutting off machine
角钢卷圆机 Angle iron rolling machine
管道切断器 Pipe cutting machine
铜管调直机 Copper pipe straightening machine
管道压槽机 Book joint setting machine for pipes
角向磨光机 Angle polishing machine
电动套丝机 Electric threading machine
电动卷扬机 Electric winch
电动试压泵 Motor-driven pressure test pump
手动试压泵 Manual pressure test pump
阀门试压机 Valve pressure test device
TDC(F)风管加工流水线 TDC(F)air ductwork fabrication
stream line
等离子切割机 Plasma cutting machine
TDC(F)法兰条成型机 TDC(F) flange strip shaping mill
勾码成型机 Forming machine for flange clamp
TDC(F)风管加工成型机 TDC(F) duct fabrication shaping mill
多普勒超声波流量检测仪 Doppler ultrasonic flow detector
温、湿度传感器 "Temperature, humidity senor"
精密声级计 Precision sound level meter
风管漏风量测试仪、风室式漏风测试装置 "Duct air leakage
tester, airchamber air leakage testing device"
风罩式风量测试仪 Air hood air rate tester
微压计、毕托管、热球(电)风速仪 "Micromanometer ,
pitot tube, hot bulb(electrical) anemoscope"
潜水泵 Submerged pump
电动弯管机 Electric pipe bender
铜管弯管机 Copper pipe bender
液压弯管机 Hydraulic pipe bender
电动剪刀 Electric clipper
液压铆钉钳 Hydraulic riveting clamp
线槽电锯 Trunking electric saw
开孔器 Tapper
电动空压机 Electric air compressor
液压千斤顶 Hydraulic jack
液压手推车 Hydraulic trolley
焊条烘干箱 Welding rod drying box
手拉葫芦 Chain block
道(垫)木 Sleeper
转速表 Tachometer
电流钳型表 Clip-style ammeter
压力表 Pressure gauge
接地电阻测试仪 Earthing resistance testing device
氧气表 Oxygen gauge
乙炔表 Acetylene gauge
对讲机 Walkie talkie
文件和资料 documents and information?
建设单位 Construction unit
安装单位 Installation unit
学生专栏
23.9 万条内容 · 138 人订阅
建筑行业常用英语词汇
建设,建筑,修建 to build, to construct 建筑学 architecture 修筑,建筑物 building 房子 house 摩天大楼 skyscraper 公寓楼 block of flats (美作:apartment block) 纪念碑 monument 宫殿 palace 庙宇 temple 皇宫,教堂 basilica 大教堂 cathedral
