土木在线论坛 \ 道路桥梁 \ 其他路桥软件 \ 谁用ANSYS建立过系杆拱桥模型?请指教
发布于:2007-12-21 09:00:21 来自:道路桥梁/其他路桥软件 [复制转发]
我在做系杆拱桥的计算,总说有错误代码如下:/COM,ANSYS RELEASE 10.0 UP20050718 17:49:23 12/05/2007
*** WARNING *** CP = 101.797 TIME= 17:54:00
Real constant 1018 referenced by at least element types 5 and 1.
*** WARNING *** CP = 101.906 TIME= 17:54:03
The program chosen initial timestep/load-factor is arbitrary. It is
necessary for the user to supply a suitable initial
timestep/load-factor through the NSUB or DELTIM command for
convergence and overall efficiency.
*** WARNING *** CP = 106.047 TIME= 17:54:10
Changing element real constants (R commands) between load steps is
generally a non-standard use of the program. Exceptions to this rule
(such as changing contact element normal stiffness) are specifically
documented in the User’s Manual.
Changing material properties (MP commands) between load steps is a
*** WARNING *** CP = 108.453 TIME= 17:54:14
At this abort point, the single-frame restart file may not be complete.
Use multi-frame restart from the last successfully converged substep.
The unconverged solution (identified as time 2 substep 999999) is
output for analysis debug purposes. Results should not be used for
any other purpose.
*** WARNING *** CP = 112.703 TIME= 17:54:19
*** WARNING *** CP = 114.875 TIME= 17:54:23
For item= AREA the component ( 9.8 ) is invalid.
The ASEL command is ignored.
*** WARNING *** CP = 115.594 TIME= 17:54:24
*** WARNING *** CP = 120.969 TIME= 17:54:32
*** WARNING *** CP = 123.047 TIME= 17:54:35
*** WARNING *** CP = 125.562 TIME= 17:54:40
Output frequency control is not allowed in an expansion pass. Only ALL
or NONE are valid.
The OUTR command is ignored.
请专家帮我解释一下.
谢谢
全部回复(3 )
  • bxb503848151
    bxb503848151 沙发
    楼主问题是一个实常数赋予了多个单元类型,可能是建模时未对不同单元类型设置实常数,
    2016-02-26 12:03:26
  • bxb503848151
    bxb503848151 板凳
    提取特征值数太少了,可以适当设大点了,只要不超过节点数就对了,
    2016-02-26 12:01:26
其他路桥软件
3.58 万条内容 · 129 人订阅
超强全功能计算器
超强全功能计算器,共6部分第一部分
