来自专筑编辑Brick,vigo的报道。这个度假住宅位于葡萄牙北部,为一个四口之家而建。其形状由相同数量的单体来确定。它们有相似的尺寸但朝向不同。其中三个房屋围绕一个核心正交组织,而第四个房屋旋转来匹配现有邻近建筑的方向。两个建筑相互邻近,产生对话。现有建筑的适度尺寸决定本项目的规模,同时本地特性影响了住宅的布局。每个房屋有两个坡屋顶。除了强调个性之外,它还能增加结构的可塑性。 From the architect. This holiday house for a family of four is located in the north of Portugal. It’s shape is defined by the same number of individual volumes. They have similar dimensions but distinct orientations. Three of the volumes are orthogonally organized around a core, whilst a fourth rotates to match the direction of an existing neighbouring building. The proximity between the two constructions led to a desired dialogue. The modest dimensions of the existing building determined the scale of the house while the vernacular identity influenced its layout. Each volume has a two slope roof. Besides emphasizing its individuality it enabled to increase the plasticity of the composition.
© Joao Morgado
1人已打赏
居住建筑设计
返回版块28.74 万条内容 · 423 人订阅
最复杂的木榫建筑工程——岩石山小房/ Helen & Hard来自专筑编辑雷君的报道。梅奥告诉我,他选择了一个与众不同的建筑项目。这个建筑中不只是CLT或胶合木,还具有适应性和灵活性的独特木材。其中一个代表是这个为挪威斯塔万格登山协会提供服务的三层的旅馆。Helen & Hard事务所在该建筑中没有采用CLT,胶合木,或单板层积材,而是使用榫木板平行的承重剪力墙。梅奥写道,“该项目可能是最复杂的木榫建筑工程。”Mayo told me that he selected projects that have different way of doing things. They are not just CLT or glulam; they exhibit the adaptability and flexibility of wood while responding to unique problems. One standout is this three-story lodge that serves the Stavanger Trekking Association in Norway. Instead of CLT, glulam, or LVL, architects Helen & Hard used doweled wood panels parallel load-bearing shear walls. Mayo writes it "may be the most complex wood doweled building ever built."
全部回复(3 )
只看楼主 我来说两句-
zgw711
沙发
谢谢楼主分享
2015-07-16 12:05:16
niniguo58
板凳
谢谢楼主分享
2015-07-16 09:41:16
加载更多回复 举报
