© Amit Geron
建筑师 Pitsou Kedem 为自己家设计的住宅所在街区是 1950 年由队伍军人所建,在茂密的桉树林里,其低矮的轮廓和水平线条显得格外突出。Kedem的家融入了周边建筑群中,使用了现代建筑形式。 From the architect. The neighborhood where architect Pitsou Kedem designed a home for himself and his family was established in the 1950’s by army veterans and can be characterized by buildings with low silhouettes and horizontal lines set in a rich grove of eucalyptus trees. Kedem’s home was designed to blend in with the architectural characteristics of the other homes, all built using modern architectural values.
© Amit Geron
© Amit Geron
住宅结合了例如混凝土楼板和连排的窗户等元素,也采用了最原始的材质状态: 外露的混凝土、 铁、没上色的木材和硅酸盐砖。这些使用的例子从入口天花就能看出,一个连续的窗贯穿整个长度。这使得天花从结构墙区分开,在整个建筑体和通向悬浮入口大堂那漆成白色的铁质坡道中创建一种微妙的感觉。 The home combines elements such as a concrete ceiling and continuous windows and also uses materials in their original, raw state: exposed concrete, iron and uncolored wood and silicate bricks. Examples of the use of such materials can be found in the concrete ceiling that floats above the entrance floor with a continuous window along its entire length. This allows the ceiling to be separate from the structure’s walls and creates a feeling of etherealness in the buildings mass and the white painted, iron ramp that leads to the floating entrance lobby.
Floor Plan/平面图
© Amit Geron
© Amit Geron
© Amit Geron
门在建筑的中间穿过楼梯之间的部分,面向一个固定的无框窗口。透过窗户,我们看到环绕整个布局的桉树。楼梯由特殊纹理的金属材料制成,未覆盖任何面层材料。它把上下两层分为两个矩形,分别由支撑屋顶的裸露结构组成的两面墙界定。由木条封印的天花透下光照亮整个室内。墙内嵌入不同尺寸的圆形窗户,允许光线透过天窗分散进来。 The door is located in the center of the building at the cross section between the stairwell and it opens facing a fixed, frameless window. Through the window, we see the eucalyptus trees that surround the plot. The stairwell is constructed from metal with a unique texture and with no covering materials. It divides the two floors into rectangles and is delimitated by two walls constructed from exposed blocks that support the ceiling. Light is provided from the skylight that runs its entire length, covered by wooden slats. Set into the walls are round windows of differing sizes that allow the light coming through the skylight to disperse within the space.
© Amit Geron
房子被设计成两个正方形,上下相叠,呈倾斜布局。下层位于场所前部较低的位置,上层位于较高地方,面向道路,低处的轮廓被四季常青的瓶树隐藏。 The house was designed as two squares, set one on top of the other whilst exploiting the sloping plot. The lower level is located at the lower and front section of the plot while the upper level is located on the plot’s higher section, towards the road and whose low silhouette is hidden by evergreen Brachychiton trees.
© Amit Geron
© Amit Geron
张弛之间表现了建筑师的愿景和事实之间的平衡。这是一个围绕设计师妻子kibbutz童年记忆的理想之家。Kedem 设法避免噱头,在住宅设计中表现了这种难以捉摸的"永恒建筑"。 The restraint and scale that characterize the design express the balance created between the architect’s vision and the fact that the house, which is conceived as a family home, is designed around childhood memories of the architect’s wife’s kibbutz. Kedem sought to avoid the creation of gimmicks and to realize in the house’s design that elusive idea of “timeless architecture”.
© Amit Geron
原材料和对创造一个平凡而又永恒的建筑的尝试是向屋里的书籍和作品致敬,它们来自以色列新老艺术家,诸如:Tsvi Geva, Yadeed Rubin, Nurit Gur Lavi, Amir Shepht, Aram Gershoni, Yifat Betsalel等等。 The raw materials and the attempts to create a non-fashionable and timeless architecture compliment many books and works hanging in the homes of both young and old Israeli artists such as Tsvi Geva, Yadeed Rubin, Nurit Gur Lavi, Amir Shepht, Aram Gershoni, Yifat Betsalel and others.
© Amit Geron
© Amit Geron
© Amit Geron
© Amit Geron
房子里的家具和灯具也经过仔细的挑选,衬托视觉和气氛。包括由领先的设计师Piero Lissoni, Patricia Urquiola, Dan Yafe等设计的沙发、 地毯、桌子和书架,还包括炙手可热的设计公司的产品,包括:意大利的MDF , B&B , Desalto, Living Divani 和GAN。 The house’s furniture and light fixtures were also carefully chosen to complete the look and the atmosphere. They include sofas, carpets, tables and bookcases by leading designers such as Piero Lissoni, Patricia Urquiola, Dan Yafe and others and from leading companies including MDF italia, B&B Italia, Desalto, Living Divani and GAN.
© Amit Geron
© Amit Geron
© Amit Geron
© Amit Geron
© Amit Geron
© Amit Geron
© Amit Geron
© Amit Geron
© Amit Geron
© Amit Geron
© Amit Geron
© Amit Geron
© Amit Geron
© Amit Geron
© Amit Geron
East Elevation/东立面
Section/剖面图
建筑事务所:Pitsou Kedem Architects 地点:以色列 Ramat Hasharon 面积:380.0 平米 年份:2014年 摄影师:Amit Geron 设计团队:Pitsou Kedem, Noa Groman, Tamar Berger 摄影师:Eti Buskila |
公共建筑设计
返回版块51.18 万条内容 · 448 人订阅
2015年度蛇形馆设计方案© Steven Kevin Howson / SelgasCano 第十五届蛇形画廊是由西班牙的设计师SelgasCano设计而成的,于周四在伦敦的克星顿公园对外开放。The 15th Serpentine Gallery Pavilion, designed by Spain's SelgasCano, opens to the public on Thursday in London's Kensington Gardens.
全部回复(3 )
只看楼主 我来说两句-
lijiawei411
沙发
谢谢楼主分享的好资料
2018-09-06 15:57:06
石大侠
板凳
好设计!赞一个!
2015-11-30 23:03:30
加载更多回复 举报
