土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 中国山东日照游客中心设计方案
中国山东日照游客中心设计方案
发布于:2015-06-14 15:02:14 来自:建筑设计/公共建筑设计 [复制转发]
Visitor Center
设计方:HHD_FUN Architects
位置:山东 日照
摄影师: Zhenfei Wang, Chenggui Wang
日照游客中心位于两公里长的山海天海滩公园北部,建筑毗邻一个广场,在旺季会吸引很多游客前来。游客中心共两层,露出地面的部分采用尽量小的体量以融入周围景观环境中,同时地下层的面积则非常大,功能齐全,比如商店、电影院、餐厅、休闲设施、公共淋浴房等。游客主要从广场进入建筑东侧的部分,可以通过三个开放楼梯进入建筑,也可以通过四条路到达大海。19座相互独立的建筑都取自同一个原型,但每个建筑的位置、大小和朝向都有所不同,以适应多种多样的功能。这些建筑的集合体形成了一种新颖的形式,创造出多种多样的室内和室外空间。空间钢桁架不但可以适应这座复杂建筑形体塑造的需求,同时也能创造出大跨度空间。从设计形体到建筑表皮到建设文件的编制,参数化技术应用到了整个设计过程中,以保证这个设计方案能够让当地技术条件不足的建设方成功的实施。“低技术参数化设计”是这些设计师应对目前中国建筑市场的一个策略。
Rizhao Visitor Center was located on the North part of the 2km long Shanhaitian beach park in Rizhao, east China. Vistor Center is adjacent to a plaza which will attract massive tourists during the high season. The Vistor Center consists of two floors. The form of the building above ground was minimized in order to fit into the natrual environment while at the same time the underground part of the building offers various functions for the park. For instance, shops, cinemas, resturants, leisure facilities, public showerrooms etc. Pedestrains will mainly enter the plaza from the east side, either through 3 open stairs into the building or 4 different pathways towards the sea.All 19 individual buildings were developed out of one prototype. Each building is site specific; being varies in sizes and different orientations to accommodate different function requirements. Together a group of them generate a new configuration that has the emphasis on the varieties of the indoor and outdoor spaces. Special steel structure was designed to fit the complex building form at the same time create big span column free space.Parametric design technique has been adopted throughout all design process i.e. form finding, structure optimization, facade penalization and construction documentation, which make sure the complex shape can be “made” by local low technology manufacturer. “Low Technology Parametric Design” is our strategy to face China’s current construction situation.
全部回复(5 )
  • lijiawei411
    lijiawei411 沙发
    好资料,谢谢分享。
    2019-07-16 10:56:16
  • 园林居士
    园林居士 板凳
    找到了谢谢提供
    2019-07-16 10:14:16
公共建筑设计
51.18 万条内容 · 448 人订阅
法国巴黎紫色星辰电影院
étoile lilas cinema 设计方:hardel & le bihan 位置:法国 巴黎 竣工:2012年 摄影师:vincent fillon 建筑面积:4450平方米造价:900万欧元在巴黎东郊的第20区,紫色星辰电影院成为了郊区开发的一个新亮点,由巴黎设计师hardel & le bihan设计,这座建筑周围是住宅、活动区和公园,缺乏剧院等其他娱乐场所,所以新电影院的建设对周边社区来说非常重要。底层的体块非常低调,临街设置了一些零售商店,为过路的行人提供服务,从地面开始,一个上升的玻璃走廊引导来客进入上层的公共空间,黑色的主体与透明的走廊形成了鲜明对比,在周围环境中非常醒目。封闭的玻璃走廊围绕着黑色的实体体量上升,经过一个室外平台,在这个高台上可以欣赏周围的全景,迷宫似的花园内产生了许多有趣的“微空间”,在这里可以进行室外放映、举办聚会或是其他活动。走廊继续围绕主体快上升,直到最上层。封闭在黑色表皮内部的是多彩的银幕空间。
