土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 日本田中诊所设计方案
日本田中诊所设计方案
发布于:2015-06-11 21:25:11 来自:建筑设计/公共建筑设计 [复制转发]
Japan tanaka clinic
设计方:Akiyoshi Takagi & Associates
位置:日本
诊所有一个大屋顶,还有一个毗连的花园。诊所里有各种各样的房间,比如康复室和检查室,每个房间的大小也各有不同。考虑到对诊所室内净高的要求,诊所有一个很大的平屋顶,屋顶向一方倾斜。诊所拥有更高天花板的那一边被用来做病患区,而天花板较矮的那一边用来做检查室。屋顶向外延伸很多,为人们创造了一个进出口走廊和有屋顶的人行道。人们也可以在大屋顶下集合。病患大大部分时间都会花在等待上面。除此之外,还有一个为治疗和复原开会的骨科病室。患者要定期的来诊所进行复原,而他们的能动性和自主性对完全康复非常重要。
因为病患要在候诊室和复原室花很多时间,为了给病患提供一个更舒适、放松的空间,我们修建了一个绿树成荫的花园,可供来访者欣赏随季节变化而改变的植被。别墅的大窗户位于别墅外部结构相对隐蔽的区域,正对着花园。因此,花园隐蔽在走廊和房檐中间,从而变得有点像内部花园。这使诊所内外空间有了充足的距离。
Utilizing the large roof and adjacent garden The clinic is composed of various rooms, such as the rehabilitation room and exam rooms, that range in size from large to small. The ceiling height takes this into consideration, using a large, flat roof that slants to one side. The side with higher ceiling clearance is dedicated to patient spaces, while the lower side is used for examination rooms. The eaves extend considerably, creating an intake/exit lane for arrivals/departures and a roof covering for pedestrians. People can also congregate beneath the large roof.The majority of patients’ time will be spent “waiting” at the clinic. In addition, an orthopedic clinic involves long sessions for treatment and rehabilitation. Patients have to regularly commute to the clinic for rehabilitation, and their feelings of motility and freedom are essential for proper recovery.
Seeking to provide a more comfortable and easy space for patients, who will be spending long periods of time in the waiting rooms and in the rehabilitation room, we devised a tree-lined garden that would allow visitors to enjoy the changing flora and foliage of the seasons. The large window facing the garden is positioned in a secluded location relative to the outer perimeter of the structure. The garden is thus ensconced by the corridor and eaves and becomes a sort of inner garden. This generates an adequate distance between the interior and exterior.
日本田中诊所剖面图
全部回复(3 )
  • 老建筑人生
    东西不错啊,感激楼主的
    2016-07-14 10:56:14
  • cmlhjcfs
    cmlhjcfs 板凳
    很有特色的建筑,学习了,谢谢。
    2016-03-18 22:56:18
公共建筑设计
51.18 万条内容 · 448 人订阅
智利迈普埃尔卡门医院设计方案
Chile Mpe el Carmen Hospital 位置:智利 建筑设计:BBATS Consulting&Projects SLP 迈普埃尔卡门医院面积70301平方米,医院里面有375个床位、11个手术室、6个产房、125个咨询服务处、523个车位和347个抗地震避震器,医院里面一共有1500个员工,医院坐落在乡下人口最密集的场所中。别墅的场址是边长250米的正方形,场址中有面积相当大的绿地,还有足够的空间去决定修建建筑物的场所。项目的挑战来源于地面重大的差异,南部的入口和北部的入口之间有10米的高度上差异,于是产生了一个斜坡,与建筑项目主墙边的大道之间形成了一个对角线。
