土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 法国医疗健康中心设计方案
法国医疗健康中心设计方案
发布于:2015-06-11 19:03:11 来自:建筑设计/公共建筑设计 [复制转发]
P?le Santé Val de Cher health centre by Oglo
设计方:Oglo
位置:法国
这是由Oglo建立的医疗健康中心,位于法国郊外谢尔河上的塞勒小镇。病人们可以坐在休息室里的时候眺望周围的田地或者室外花园。Oglo在一个一层高的白色小楼里建立了一个很简单的视觉语言办公室。透过落地窗可以清楚的看到各种医疗设施,包括医生、牙医、护士、物理治疗师等办公室以及药店和医疗实验室。
由于Oglo坐落在土地平坦的郊区,所以在它们的对面有一个可以通车的大型园景区和停车场。建筑师解释道:“通过利用区域的低密度,该项目与景观区和种植区中央存在着特定的联系。”透过每栋楼墙上的小窗户阳光可以进入治疗室。
休息室有全落地窗因此患者可以欣赏到庭院或者更远的建筑。该项目的经费除了由病人承担外,简单的建筑风格和使用耐用材料也是降低成本的一个重要因素。
Patients at this health centre on the outskirts of the French town of Selles-sur-Cher can look in towards a small landscaped garden or out at the surrounding fields while they sit in the waiting room (+ slideshow).
Paris studio Oglo developed a simple visual language of white one-storey buildings with vertical windows to unite the various healthcare facilities, which include the offices of doctors, a dentist, a nurse, a physiotherapist, a pharmacy and a medical laboratory.
Located on a suburban estate, the banality of the surrounding landscape led Oglo to position the buildings so they face each other and look onto a large landscaped area across access roads and parking spaces.
"By taking advantage of the zone's low density, the project engages in a particular relationship with the landscape and the planted areas at its centre," explained the architects.Narrow openings punctuate the walls of each building and allow a soft light to enter the treatment rooms.
A waiting room at the centre of the complex features full-height glazing on two sides so patients can look out onto the courtyard or the fields beyond the buildings.
The project was financed by its occupants and the simple architectural style and choice of robust materials were a direct result of the need to minimise costs.
法国医疗健康中心
  • cmlhjcfs
    cmlhjcfs 沙发
    好环境,好建筑,谢谢提供赏析。
    2016-03-16 23:02:16
公共建筑设计
51.18 万条内容 · 448 人订阅
西班牙索菲亚公主医院设计方案
Infanta Sofía Hospital / PardoTapia Arquitectos 设计方:PardoTapia Arquitectos 位置:西班牙 合作人:Stefano Presi (coordinador); StefaniaAlbiero 结构师:NECSO-PONDIO-VALLADARES 项目规模:126,790平方米 这是由Arquitectos设计的索菲亚公主医院,位于西班牙。建筑本身为东西朝向,这个东西朝向的建筑将空间分割成两个部分,形成了内外的分界线。一个垂直电梯密切了内部与外部的联系。在整个建筑的北边是项目的核心区域,这里是医疗咨询中心,中心后面则是技术协助办公区。建筑的北部有医生办公室和咨询部门。建筑造型简单,呈现单一的循环形式。设计师利用集装箱的设置,将建筑的三层与急救区相连。
