土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 西班牙索菲亚公主医院设计方案
西班牙索菲亚公主医院设计方案
发布于:2015-06-11 18:48:11 来自:建筑设计/公共建筑设计 [复制转发]
Infanta Sofía Hospital / PardoTapia Arquitectos
设计方:PardoTapia Arquitectos
位置:西班牙
合作人:Stefano Presi (coordinador); StefaniaAlbiero
结构师:NECSO-PONDIO-VALLADARES
项目规模:126,790平方米
这是由Arquitectos设计的索菲亚公主医院,位于西班牙。建筑本身为东西朝向,这个东西朝向的建筑将空间分割成两个部分,形成了内外的分界线。一个垂直电梯密切了内部与外部的联系。在整个建筑的北边是项目的核心区域,这里是医疗咨询中心,中心后面则是技术协助办公区。建筑的北部有医生办公室和咨询部门。建筑造型简单,呈现单一的循环形式。设计师利用集装箱的设置,将建筑的三层与急救区相连。
在这个项目中,还有一个大型的“市长广场”,该广场里面有长廊、电梯和停车区,并且形成了一个与外界联系的医生办公区域,该广场还直接与康复服务中心相连。建筑长18米,宽25.20米,外形为方形。建筑物与建筑物之间离得很近,可以用来应对突发事件,也可以方便自己与不同楼层的人联系。
The building structures itself around an orientation axis East – West and acts as a dividing line between the most external zones and the most internal ones. (Technical Block) This axis contains two circulation lines separated by a fringe in which are located the vertical elevators nucleus (restricted area) and stairways in such a way that the nucleus situated to the North joins across the medical consults zone and bureaus ( half public controlled access) and the rear one that joins the assistance areas of the technical block (restricted area).
On each side of this axis are perpendicular connected “functional containers” separated by courtyards fringes. Those situated to the north are adapted for doctor?s offices and bureaus. This process hollow empty is repeated along the north fringe of the building creating another double circulation that joins in the upper side these blocks, it is use 36 containers as the related before in the three floors of this building zone for solving the PF of the ambulatories zones.
The preceding arrangement interrupts towards the west wing generating a large vacuum “Mayor Square” that connects with the parking area by means of a ramp and elevators, this square is traversed for a covered gallery enabling to cross the building fringe in which are the external doctor?s offices and access to the main axis where it is located the technical block.
The fringe of the “functional containers” of the technical block is solved using an element of 18 m. per 25,20 m. width. The grouping (modules) according to the upright coordinate axis “Y”, of this element separated by courtyards of 4,20 m.width, allows to use a block of 66,20 m. long and 25,20 m.
These blocks are separated by non-building fringes (courtyards) of 10,80 m. width that can be constructed in ground floor as the way of Emergencies, or connect themselves indistinctly trough catwalks for creating services with major surface requirements in the different floors of the building.
索菲亚公主医院
  • cmlhjcfs
    cmlhjcfs 沙发
    赏析了,谢谢。
    2016-03-16 23:04:16
公共建筑设计
51.18 万条内容 · 448 人订阅
意大利Borgo Trento医院设计方案
Borgo Trento hospital 设计方:福尔克温·玛格和Altieri工作室 位置:意大利 项目规模:96300平方米 Borgo Trento医院为南意大利的重要医院。意大利卫生部出台政策:在保留原有医院职能前提下对内城大型医院进行现代化翻修改造。而此处就是具体执行的试点项目医院。该项目坐落于维罗纳南部,埃施河畔,紧邻城市中心,医院包括一个新建的综合建筑群,各医学学科部门以及日常功能单位被密集地安置于其内(包括外科、急救室、病房、手术室、急诊、夜间和日间诊所、放射科以及例如店铺、餐饮等公共设施区)。大型庭园作为设计的中心理念,一方面构成了医院地块上新旧建筑之间的绿色屏障,另一方面通过运用建筑元素(蔓藤回廊、阶梯、坡道、桥梁等)塑造出宏伟大气、舒适宜人的园林空间,可供病患以及来访者逗留休憩。
