土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 智利牙科诊所设计方案
智利牙科诊所设计方案
发布于:2015-06-11 18:49:11 来自:建筑设计/公共建筑设计 [复制转发]
Chile dental clinic
位置:智利
建筑设计:Felipe Assadi与Francisca Pulido
这是由Felipe Assadi与Francisca Pulido共同设计的智利牙科诊所。这里之前是智利塔尔卡的中央电网,处于明显失修的状态,并且还有着非常贫穷的施工质量, 因此,就像牙医“修复”受损部位的工作一样,建设师Felipe Assadi与Francisca Pulido收到开发商的委托,在这里修建一个牙科诊所。企图修复这些损坏的老式建筑,在这个城市中心的角落中建设一个公益性质的项目。这个建筑内配有较为先进的医疗器械,它包含:8个独立的单间,等候室,X射线室,一个小实验室和一个大厅,并分有上下两层。此外,整个建筑用白色的30× 30厘米的陶瓷瓷砖包围,这能让人感觉到洁净和卫生。
The dental clinic Ayen is inserted into the central grid of the city of Talca, an area with an obvious state of disrepair and with a very poor quality of construction, delivering a fragmented and discontinuous environment, whose regulation was in flux at the time of the project.Thus, like the work of dentists who “repair” the damaged parts, this project is proposed as an element that tries to repair one of these damaged situations, one of the unbuilt corners of the city center which will follow the new building guidelines devised at the time of the project.But at the same time, following the analogy of the work of dentists, this piece will be, as a tooth, an element whose shape not only responds to the place where it is located, but also to the program it contains, so as not to pretend to be anything other than the representation of that which it contains: 8 separate boxes with their waiting rooms and x-ray rooms, a small laboratory and a hall, spread over two levels.In addition to the above, and to dramatize the idea of a single, monolithic piece, it is completely clad in white tile, the result of cutting a 30 x 30 cm ceramic tile, which gives a plastic and clean character the building.
智利牙科诊所-13
  • cmlhjcfs
    cmlhjcfs 沙发
    此建筑怪怪的,谢谢提供赏析。
    2016-03-18 22:27:18
  • gfh2006
    gfh2006 板凳
    挺漂亮的吗 谢谢分享
    2015-06-12 08:43:12
公共建筑设计
51.18 万条内容 · 448 人订阅
墨尔本康复医疗中心设计方案
billard leece completes a soberingly stunning rehabilitation center 设计方:billard leece 建筑时间:2013 吉隆是维多利亚州的仅次于墨尔本的第二大城市,它是一个保健康复中心地带,这里有精神治疗中心和物理治疗康复中心。设计师billard leece在这里设计了一个特别的康复医疗中心。该医疗中心的有着一个像足球一样层次的结构,整体是一个U形,项目包括个人的房间,行政中心和公共领域,分别沿着这个U形扩展。项目的庭院带有花园,内部种植着树木,可以减轻人们免受大风的摧残。建筑的结构简单,材料采用的是白松木木板,经久耐用,易于安装,还能保暖。
