土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 法国马恩河畔尚皮尼小型地区性医院
法国马恩河畔尚皮尼小型地区性医院
发布于:2015-06-11 18:19:11 来自:建筑设计/公共建筑设计 [复制转发]
100-bed hospital
设计方:A/ZC – Atelier Zündel & Cristea
位置:法国 马恩河畔尚皮尼
造价:10500000欧元
面积:6200 平米
医院为门诊病人提供90个床位,和10个附加床位。医院大楼长75米,宽17.5米,南北向布局,共有四层,带有地下室。医院入口处有一个中庭,建筑表面有棱纹彩色钢结构装饰线,在不同的位置呈现不同的颜色。大楼周围绿化完善,有一个可容纳38量车的停车场和一个自行车存放处。医院在节能方面也做出了良好的表率,建筑材料的高隔热性能,热量回收,还安装有冷凝热水器,高效能双层玻璃窗等设施。
The Hospital accommodates 90 beds with 10 additional beds for day patients. Developed to a length of 75m by a 17,5m width, the project is composed of four floors and a partial basement. The building is situated in the center of the site along the north-south axis. It is set back around 10m from the street so as to leave space for an entry courtyard. It is also set back about 12 meters from its surrounding neighbors. The rooms and living spaces are oriented east-west. The facades are in ribbed, pre-enameled steel siding. The building is surrounded with green spaces, a 38-space parking lot, and a 15-space two-wheel vehicle parking lot. In accordance with an environmental approach in which targeting energy concerns became a priority, the project was enhanced by: insulation of the exterior; double air flow with heat recovery; a condensing boiler; high-performance double glazing.
小型地区性医院-10
全部回复(6 )
  • 小郑郑
    小郑郑 沙发
    非常圆滑的建筑啊哈哈
    2016-11-08 10:21:08
  • cmlhjcfs
    cmlhjcfs 板凳
    感觉建筑清新典雅,非常合适作为医院建筑,收藏了,谢谢。
    2016-11-08 10:03:08
公共建筑设计
51.18 万条内容 · 448 人订阅
辽宁大连医科大学附属医院
Dalian Medical University Hospital 设计方:Design Initiatives 位置:辽宁 大连 面积:184828平米事务所在进行设计时将重点放在患者和医护人员的体验上。医院主要包括四个主建筑,分别是门诊部、住院部、医药部和教研行政部,中央是一个散步广场。广场分为两层,连通四栋楼的同时,为医生和患者及家属提供宁静开放的户外空间。医院临街面建有临时泊车区,车辆按规格分开进入。大楼还安装有相关的节能系统,例如废水回收,雨水收集等等。建造过程中还是用了回收材料和预制构建结构。设计师还在周围建造了地下停车场、公园、屋顶花园等。整个建筑群是钢筋支架,外覆金属板和幕墙结构建成的。
