公共建筑设计
返回版块51.18 万条内容 · 448 人订阅
美国洛杉矶创伤后应激障碍症治疗中心PTSD Treatment Center 位置:美国 洛杉矶 这个项目位于一个湿地之上,设计目标就是尽可能地保护湿地环境,因此建筑高抬于地面16英尺(4.88米),最后慢慢达到顶层的50英尺(15.24米)。一个双层的悬挑桁架系统包含所需的项目元素,它们都悬浮在景观之上。建筑的高挑感和空灵感可以吸收周围的大部门水份,减少洪水的隐患,同时还能重新疏导水流到当地的地下河流之中。Given the site, Ballona Wetlands, which are one of the few wetlands that still, remain in LA, one of the main objectives was to preserve the wetlands. The PTSD center is elevated sixteen feet off the ground gradually rising to a peak of fifty feet. A double cantilevered truss system containing the required program hovers over the landscape. It is able to absorb mass amounts of water; therefore, it is key to flood control as well as redistributing water to the local water supply of underground rivers. It is crucial that the site remains a wetland, and will continue to be a home to all its inhabitants and wildlife.
只看楼主 我来说两句 抢板凳回复 举报
