Courtesy of Sameep Padora & Associates
业主夫妇的主要想法是想建造一座房子作为他们“远离外界喧嚣的城堡”,同时希望拥有相当大的空间来经常招待朋友和客人。 From the architect. The primary program brief from the couple who owned the house was a desire to build a house that was to be their ‘fortress from the cacophony of the world outside’ while creating a sizable space to be used frequently for entertaining friends and guests.
Ground Floor Plan/底层平面图
项目参考城堡,试图平衡相对外部所需要的私密和保护以及应酬所需的分级开放空间的关系。 Referencing forts as a primer the formal development of the project attempts to balance a need for privacy/protection from the outside while developing layered and tiered open spaces for social engagement.
私密和尺度 我们首先把私密的概念从建筑尺度中分离。形式上围墙成为三面平行石灰石复合墙的一部分,升高的围墙增加了建筑和街道之间的距离感,也使坐落在其中的建筑显得尺度宜人。 Privacy & Scale Our first effort was to distance the notion of privacy from that of scale. Formally the boundary wall becomes part of the three parallel limestone clad wall set that configure program between them and ascend in height as they gain distance from the street scaling the house down to human proportions.
彻底修整庭院 项目临南侧街道的部分需要私密性和气候防护(减缓来自南方的暴晒),因此打造了一个巨大的不透水表面。但是一进入室内,建筑的坚固性就被分段重叠和多层连接的混合型庭院完全消除, 这个庭院既是内化的又是外部的,作为满足业主需求的大规模娱乐空间。庭院削减了建筑的截面宽度,连接着多个独立出入口,可进入建筑的私密空间(家庭)和公共空间(工作和娱乐),并在建筑的物理中心交汇。 Wearing the Courtyard Inside Out This need for privacy and climatic sheltering on the south side street (to mitigate the harsh southern sun) creates a largely impervious facade. The solidity of this construct is completely obliterated once inside the house by sectional overlapping and linked multilevel a hybrid courtyard that is both internalised and external and hence becomes a container for the massive entertainment space required by the client. This void/court cuts the through the sectional width of the house becoming a programmatic connect for the independently accessible strands of private (family) and public (work &entertainment) spaces that intersect in the physical centre of the house.
Site Plan/场地平面图
Section/剖面图
Section/剖面图
Detail/细节
建筑设计: Sameep Padora & Associates 项目位置: 印度安得拉邦523112, hyderabad, Ambavaram 设计团队: Viresh Mhatre, Harsha Nalwaya, Aanoshka Choksi, Mythili Shetty 项目面积: 1300.0平方米 项目时间: 2014年 摄影: Courtesy of Sameep Padora & Associates 机电设计顾问: R.N. Joshi 结构顾问: Facet Architects: Sameep Padora & Associates Location: hyderabad, Ambavaram, Andhra Pradesh 523112, India Design Team: Viresh Mhatre, Harsha Nalwaya, Aanoshka Choksi, Mythili Shetty Area: 1300.0 sqm Year: 2014 Photographs: Courtesy of Sameep Padora & Associates Mep Consultant: R.N. Joshi Structural Consultant: Facet |
1人已打赏
居住建筑设计
返回版块28.74 万条内容 · 423 人订阅
爱尔兰都柏林砖房设计方案© Alice Clancy 这个保护性结构是芒特普林森(Mount Pleasant)广场最后剩下的房子,包括一个完整的花园和与房子相连的旧马厩都完整无缺。房子本身从花园断开,而厨房则位于层高2.2米的地下室。新 “砖房”延伸形成新的开口,将位于一楼的接待室和新的厨房连接起来,同时又与花园相连接。
只看楼主 我来说两句抢地板回复 举报
