© Alice Clancy
这个保护性结构是芒特普林森(Mount Pleasant)广场最后剩下的房子,包括一个完整的花园和与房子相连的旧马厩都完整无缺。房子本身从花园断开,而厨房则位于层高2.2米的地下室。新 “砖房”延伸形成新的开口,将位于一楼的接待室和新的厨房连接起来,同时又与花园相连接。 From the architect. This protected Structure in Mount Pleasant Sq is the last remaining house with the full garden and original mews house connected and fully intact. The house itself was disconnected from the garden and the kitchen was in the basement with ceilings of 2.2metres. The new ‘Brick Addition’ extension allows a new opening to connect the ground floor reception rooms to the new kitchen within while connecting on to the garden beyond.
© Alice Clancy
形式 砖延伸的形式来源于提供最大内部空间的需要,以最大限度地增加北立面的自然光,并减少在邻居的阴影,以遵守都柏林市议会保护提出的严格准则。通过上部体块退台式设计,以尽可能获得深入到地面的自然光,房子的屋顶设计也是倾斜的以尽量减少房子的阴影对邻居的影响,同时将两个体块与现有房子连接。 Form The form of the brick extension is derived from the need to provide maximum internal space, to maximise natural light on this North facing elevation, to minimise over shadowing to the neighbours and to comply with the strict guidelines of the Dublin City Council conservation officer. The form evolved by allowing the upper volume to recess into the lower volumn, then by stepping the upper volumn it was possible to get natural light deep into the ground floor plan, the roofs are pitched to minimise the overshadowing to the neighbour and relate the two volumns to the existing house.
© Alice Clancy
Section/剖面图
体量与材质 住宅形式集中,使得两个体块给人以最大的重量感。集中式的布置使得新的体块沿着原来的房子自然地延伸,并向花园打开。再生砖和再生混凝土的使用使得新的体块延伸给人以永恒感。一楼结构是阶梯式的,使得上部的体块悬挂在地面的下部体块上面,而转角窗轻巧的坐落在悬臂砖墙下。 Mass and Materiality The form was massed to give the impression of maximum weight to the two volumns. The massing allows the new extension to sit alongside the original house comfortably while also opening up to the garden. The use of reclaimed bricks and reclaimed concrete sills gives the new extension a sense of permanence. The first floor structure is stepped to allow the volumn to hang weightlessly with the ground floor volumn while the corner window sits under a weightless cantilevered brick wall.
© Alice Clancy
总结 一楼的平面及使用已经从根本上改变了与花园及马厩的连接,给人以焕然一新的感觉。新体块的延伸与现有的房子完美结合,砖房的增加也使得露台有时代感。 Summary The plan and use of the ground floor has been radically changed with a new sense of connection with the garden and mews house beyond. The extension sits with a sense of harmony binding with the existing house and compliments the terrace with a ‘Brick Addition’ that is also of its time.
© Alice Clancy
© Alice Clancy
© Alice Clancy
© Alice Clancy
Site Plan/场地平面图
Floor Plan/平面图
North Elevation/北立面
建筑师:NOJI建筑师 位置:爱尔兰都柏林 合作者:John Monahan 面积:234.0平方米 时间:2014年 摄影: Alice Clancy Architects: NOJI Architects Location: Dublin, Ireland Collaborators: John Monahan Area: 234.0 sqm Year: 2014 Photographs: Alice Clancy |
1人已打赏
居住建筑设计
返回版块28.74 万条内容 · 423 人订阅
日本东京A 住宅设计方案这个紧凑的私人住宅坐落在东京人口稠密的西麻布地区。这个街区有着拥挤的街道和布满传统的低层住宅。毗邻这个街区有个公园。每当春天樱花盛开的时候,公园里便超负荷地挤满了赏樱的人群。在这个136平方米的住宅里包含了五个水平划分的空间。每个空间都由极小的雕刻般的螺旋体连接在一起,这种亲密的交接关系使这个住宅拥有了阁楼一样的私密特质。住宅超大的窗户强调了它的立面。每个窗户都拥有双层玻璃,一层是透明的,另一层是磨砂玻璃。这些双层大窗户可以任意搭配,来调节洒向室内的光线。
只看楼主 我来说两句 抢板凳
