电气资料库
返回版块70.19 万条内容 · 799 人订阅
短路电流计算C因子C Factor of ETAP Short Circuit Current Calculation-IEC Standard In this group of ETAP, youspecify if the maximum or minimum short circuit current to be calculated andbased on the selection, different c factors will be used to modify sourcevoltage. There are three options available: Max, User-Defined c Factor, andMin. When the Max option is selected, the maximum values for c factor is usedto calculate maximum fault current:
只看楼主 我来说两句 抢板凳
