土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 迈阿密的佛罗里达乡土住宅
迈阿密的佛罗里达乡土住宅
发布于:2015-05-31 07:03:31 来自:建筑设计/居住建筑设计 [复制转发]
photo by stefani fachini
这栋只有一层的住宅建造在位于热带的迈阿密,已经竣工,该建筑使用了代表着被设计团队称作“看似被遗忘的美国乡土”的材料。该建筑由Brillhart建筑事务所构思,是一个简单的、实用的客户自己建造的家庭住宅。
built in tropical miami, this single storey home has been completed using materials that reference what the design team terms ‘the seemingly forgotten american vernacular’. conceived by brillhart architecture, the dwelling is an ambitious self-build project that serves as a simple and practical family home.
前方的门廊以及植物为住宅提供了额外的活动空间/porches at the front and rear of the property provide additional floor space
阳光透过木格栅照射进门廊/light enters the porch through slatted timber screens. photo by stefani fachini
住宅被抬升至地面上的5英尺处,项目包括了100英尺的连续玻璃立面——其中50英尺跨越了正立面和背立面的整个长度。并且,4组滑动玻璃门使得住宅在需要时可以完全打开。位于建筑平面前、后的两个门廊不仅提供了额外的地面空间,同时保证了住宅的隐私性,并保护住宅与地区的一些元素相隔离。
elevated five feet above the ground, the project includes 100 feet of uninterrupted glazing – 50 feet spanning the full length of both the front and back sides. furthermore, four sets of sliding glass doors allow the residence to be entirely open when desired. two porches at both the front and rear of the plan not only provide additional floor space, but also ensure privacy and protection against the region’s elements.
书架占用了一整壁墙/a bookshelf occupies the entirety of one wall. photo by stefani fachini
厨房和餐厅/kitchen and dining area. photo by jake brillhart
厨房里的大理石操作/marble work-surfaces within the kitchen. photo by bruce buck
卧室/sleeping accommodation. photo by bruce buck
浴室/bathroom. photo by bruce buck
房屋背面的另一个走廊/another porch is found at the rear of the home. photo by stefani fachini
平面图/floor plan / level 0
剖面图/section
立面图/elevation
立面图/elevation
立面图/elevation
立面图/elevation
立面图/elevation
建筑剖面/building section
夜景图/the dwelling gently illuminated at night. photo by stefani fachini
居住建筑设计
28.74 万条内容 · 423 人订阅
迈加拉山与平原之间的住宅
image © petrosperakis 一栋由希腊建筑事务所“tense architecture network”设计的三角形混凝土建筑物作为住宅伫立在在迈加拉平原与迈加拉山脉之间,这栋住宅坐落在超过300棵橄榄树的海洋中,并以其地形为线索,成为了更加与生态系统共生的一部分。设计的设想很直接,一个三角形的空间汇聚了投向旁边山脉的视线,并用壳状混凝土将一部分住宅折叠、开放并巧妙的隐藏起来。住宅有两座庭院,一座位于南边的入口处,一座是位于内部卧室之间的天井,为内部空间提供了充足的自然采光和通风,同时整合了环境的自然优势并将其带入建筑中。一个种植了几种当地植物的绿色坡屋顶增加了该地区植物区系,同时对外部的热能量提供了一种有效的天然绝缘膜。深悬的和可操作的玻璃墙保证了根据气候可控的内部环境,并可以全部打开,变成外部空间的延续。建筑外部的混凝土分区,在形成对平原和山脉的大开放性扩展视野的同时,被用作对隐私的保护屏障,其中细长的垂直的开口在控制视线的同时也没有完全忽略自然采光。
