image © petrosperakis
一栋由希腊建筑事务所“tense architecture network”设计的三角形混凝土建筑物作为住宅伫立在在迈加拉平原与迈加拉山脉之间,这栋住宅坐落在超过300棵橄榄树的海洋中,并以其地形为线索,成为了更加与生态系统共生的一部分。设计的设想很直接,一个三角形的空间汇聚了投向旁边山脉的视线,并用壳状混凝土将一部分住宅折叠、开放并巧妙的隐藏起来。住宅有两座庭院,一座位于南边的入口处,一座是位于内部卧室之间的天井,为内部空间提供了充足的自然采光和通风,同时整合了环境的自然优势并将其带入建筑中。一个种植了几种当地植物的绿色坡屋顶增加了该地区植物区系,同时对外部的热能量提供了一种有效的天然绝缘膜。深悬的和可操作的玻璃墙保证了根据气候可控的内部环境,并可以全部打开,变成外部空间的延续。建筑外部的混凝土分区,在形成对平原和山脉的大开放性扩展视野的同时,被用作对隐私的保护屏障,其中细长的垂直的开口在控制视线的同时也没有完全忽略自然采光。 in between the megara plain and the gerania mountains, a triangular concrete structure designed by greek studio tense architecture network serves as a home lost amidst a sea of over 300 olive trees that takes cues from its landscape in an effort to become a more symbiotic part of its ecosystem. the premise of the design is straight forward, a triangular footprint that funnels views to the nearby mountains made of a concrete shell that folds, opens, and strategically conceals parts of the house. two courtyards, one at the southern entrance and one internal patio located between the bedrooms, afford plenty of natural light and ventilation to the interior spaces while helping to integrate the natural benefits of the environment into the home. a pitched green roof cultivating several native plant species adds to the flora of the area while at the same time provides an effective natural insulating membrane to the thermal mass. deep overhangs and operable glass walls ensure a climatically controlled interior environment that can open to become an extension of the exterior. the outer concrete partitions, while forming large openings extending views over the plain and mountains, are also used as protective barriers from the elements and to support privacy, which slender vertical openings controlling views without entirely neglecting natural light.
north facade/北立面。image © petrosperakis
solid concrete wall controls views and direct sunlight/坚固的混凝土墙控制了视野及阳光直射。image © petrosperakis
entry into a protected courtyard/通往隐逸庭院的入口。image © petrosperakis
large glass walls open to the exterior elements/大尺度玻璃墙向内部元素开放。image © petrosperakis
view towards the main entry/面向主入口的景观。image © petrosperakis
kitchen and dining area- a custom fireplace mantel spans to become a dining table, terminating into the kitchen island/厨房及用餐区—传统的壁炉台一直延伸到料理台,成为餐桌。image © petrosperakis
large overhanging eaves control direct sunlight/大型悬吊屋檐控制了阳光直射。image © petrosperakis
site plan/地形图
site plan/地形图
floor plan/平面图
roof plan/屋顶图
Section/剖面
Elevation/立面
Elevation/立面
Elevation/立面
Perspective/透视图
项目信息: 占地面积:11000 ㎡ 建筑用地面积: 200㎡ 建筑时间:2011年-2014年 项目团队:tilemachosandrianopoulos, kostasmavros, thanosbampanelos 合作方:athanasioskontizas_structural engineering 摄影:petrosperakis project info: site area: 11.000 m2 groundfloor area: 200m2 construction: 2011-2014 project team: tilemachosandrianopoulos, kostasmavros, thanosbampanelos collaborator: athanasioskontizas_structural engineering photography: petrosperakis |
1人已打赏
居住建筑设计
返回版块28.74 万条内容 · 423 人订阅
只看楼主 我来说两句 抢板凳
