© Fabio Pitrez
这个建筑项目的主要理念是将树木纳入建筑,结合绿色能源,在自然元素和建筑物之间创造无间隙的衔接。 From the architect. The main concept of the architectural project was to house a tree in a building that integrates environmental energies and creates a clear dialog between the natural elements and the building.
© Fabio Pitrez
© Fabio Pitrez
这个建筑是在巴西葡萄树的环绕中建成的,房主对这种树有着深深的情感。它们属于这个住宅,房主在这里度过了她的童年,建筑项目实现了她童年的梦想,在心爱的树木周围创造一个概念性住宅。 The building develops in the surrounds of a jabuticaba tree that has an emotional value to the owners. The three belonged to the house where the owner lived her childhood, and the architectural project became a childhood dream realization; to create a conceptual house in the surroundings of that beloved tree.
© Fabio Pitrez
初步的设计目标是使建筑整个采纳自然光照和通风,使得建筑对环境影响降到最小,使它和周围绿色资源最大交融。一个排水系统被设计出来以利用房高接收屋顶的雨水,并通过重力分布到整个住宅。 The primary conceptual goal of the project was to house the natural illumination and ventilation throughout the building, minimizing the environmental impact of the construction and maximizing its interaction with the surroundings energies. A water drain system was projected to use the height of the house to harvest rainwater on the roof and distribute it throughout the house by gravity.
Floor plan/平面图
© Fabio Pitrez
这个空间构造围绕着巴西葡萄树,使得早晨的阳光照进公共区和住宅的部分私密区。住宅朝东大面积开敞,使得全天阳光充足,同时东部的盛行风也可以吹到屋里。在朝北的正面,一个线形花园紧随而建和上层的房屋协调一致。在白天这个花园作为反光物散射光线到房间里,同时在晚上园内照明投影到房屋外围,形成了开放式大片墙的不规则形状。 The spaces composition surrounding the Jabuticabeira allows for morning sunlight to reach the social area and part of the intimate area of the house. Large openings to the east permit mild sunlight throughout the day, while allowing ample access of the dominant breeze that comes from the east in this geographic location. On the northern façade, a linear garden was created to follow in lines with the superior floor rooms. During the day, this garden works as a reflector of diffuse light into these rooms, while, at night, its internal illumination is projected to the outside of the house, acquiring the irregular shapes of the large wall openings.
© Fabio Pitrez
在住所朝北一面,一个水平百叶的挡风控制了进入房间的阳光,提供了更私密的环境。 On the dormitories facing north, a horizontal brise controls the sunlight access into the rooms, providing them with a more private environment.
Section/剖面图
© Fabio Pitrez
© Fabio Pitrez
内部的流线被很好地界定,将私密区和公共区、服务区分隔开来。叠加的体量也强调了正面形状的显著差别。 The internal flow is well defined and separates the intimate area from the social and service areas. The superposed volumes also emphasize these marked differences in forms in the facade.
© Fabio Pitrez
© Fabio Pitrez
© Fabio Pitrez
© Fabio Pitrez
© Fabio Pitrez
© Fabio Pitrez
Floor Plan/平面图
Elevation/立面图
Elevation/立面图
Section/剖面图
© Fabio Pitrez
建筑公司:RaffoArquitetura 位置:巴西Alphaville,Londrina–PR 建筑设计:LucasRaffo 面积:540平方米 年代:2012 摄影:Fabio Pitrez 室内设计:LucasRaffo 景观设计:Ricardo Armando, Flora Decari Architects:RaffoArquitetura Location:Alphaville,Londrina–PR,Brazil ArchitecturalDesign:LucasRaffo Area:540.0sqm Year:2012 Photographs: Fabio Pitrez InteriorDesign:LucasRaffo Landscape Design : Ricardo Armando, Flora Decari |
© Fabio Pitrez
© Fabio Pitrez
© Fabio Pitrez
© Fabio Pitrez
Floor plan/平面图
© Fabio Pitrez
© Fabio Pitrez
Section/剖面图
© Fabio Pitrez
© Fabio Pitrez
© Fabio Pitrez
© Fabio Pitrez
© Fabio Pitrez
© Fabio Pitrez
© Fabio Pitrez
© Fabio Pitrez
Floor Plan/平面图
Elevation/立面图
Elevation/立面图
Section/剖面图
© Fabio Pitrez
1人已打赏
居住建筑设计
返回版块28.74 万条内容 · 423 人订阅
住宅与荷兰景致的低调融合这栋在荷兰的住宅设计遵循严格的单层建筑层高限制规定。建筑由荷兰建筑师事务所waterstudio.nl的 koen olthuis 设计,在地下层使用了附加的楼层空间,在尺度上受限制的建筑围护结构中提供了附加的表面。this residential property in the netherlands has been designed to comply with strict regulations that limit the height of the single storey structure. completed by koen olthuis of dutch architecture practice waterstudio.nl, the property utilizes additional floor space at a subterranean level, providing extra surface within the limited dimensions of the building envelope.
只看楼主 我来说两句 抢板凳
