这栋在荷兰的住宅设计遵循严格的单层建筑层高限制规定。建筑由荷兰建筑师事务所waterstudio.nl的 koen olthuis 设计,在地下层使用了附加的楼层空间,在尺度上受限制的建筑围护结构中提供了附加的表面。 this residential property in the netherlands has been designed to comply with strict regulations that limit the height of the single storey structure. completed by koen olthuis of dutch architecture practice waterstudio.nl, the property utilizes additional floor space at a subterranean level, providing extra surface within the limited dimensions of the building envelope.
建筑由带有大面积玻璃表面的白色框架构成/the building is formed of a white frame that outlines large surfaces of glass. images courtesy of koen olthuis / waterstudio.nl 建筑由一个白色的、勾勒出巨大玻璃表面的框架构成,与总体上触觉很温暖的木材相协调。入口处的设计使住宅使用者可以尽情享受清晨的阳光,同时建筑的立面在可丽耐和玻璃材料之间交替。 the building is formed of a white frame that outlines large surfaces of glass, offset with integrated touches of warm timber. the entrance has been designed to be a space for the dwelling’s occupants to take in the morning sun, while façades alternate between corian and glass.
整个住宅整合了木质材料温和的质感/the dwelling integrates touches of warm timber. images courtesy of koen olthuis / waterstudio.nl
一层有起居室,厨房和餐厅/the ground floor contains a living room, kitchen and a dining room. images courtesy of koen olthuis / waterstudio.nl
地下层的卫生间/the home’s bathroom at lower level. images courtesy of koen olthuis / waterstudio.nl 为了延续整个设计方案的透明的感觉,建筑内部使用了最小数量的门。第一层包含了一个起居室,厨房和餐厅,而卧室和私密功能被放置在地面以下。koen olthuis同时负责了建筑的室内设计和景观设计,他在一个简单的花园引入了流动的水。 continuing the sense of transparency that pervades the scheme, a minimal amount of doors are used inside the home.the ground floor contains a living room, kitchen and a dining room, while bedrooms and private programs are positioned below grade. koen olthuis was also responsible for the project’s interiors and landscaping, where a simple garden introduces a flow of water inside the plot.
入口被设计为一个能够看到朝阳的空间/the entrance has been designed to be a space to take in the morning sun. images courtesy of koen olthuis / waterstudio.nl
整个住宅采用了夹层/the property utilizes additional floor space at a subterranean storey. images courtesy of koen olthuis / waterstudio.nl
房子的特殊结构成为了周边环境的相框/the house frames views of the surrounding landscape. images courtesy of koen olthuis / waterstudio.nl
住宅背面的露台/a terrace at the rear of the residence. images courtesy of koen olthuis / waterstudio.nl
平面/site plan
一层平面/floor plan / level 0
地下层平面/floor plan / level -1
剖面/section
剖面/section
立面/elevation
立面/elevation 项目信息 名称:新水滨别墅 地理位置:荷兰 westland 完成时间:2014年 摄影:architect koen olthuis / waterstudio.nl 建筑设计:koen olthuis / waterstudio.nl 委托人:van der arend 一家 承包商: van leent bouwbedrijf 灯光设计:stout lighting 粉刷:corian dupont project info: name: villa new water location: westland, the netherlands completed: 2014 photography: architect koen olthuis / waterstudio.nl architect: koen olthuis / waterstudio.nl client: van der arend family contractor: van leent bouwbedrijf lighting: stout lighting cladding: corian dupont |
images courtesy of koen olthuis / waterstudio.nl 这栋在荷兰的住宅设计遵循严格的单层建筑层高限制规定。建筑由荷兰建筑师事务所waterstudio.nl的 koen olthuis 设计,在地下层使用了附加的楼层空间,在尺度上受限制的建筑围护结构中提供了附加的表面。 this residential property in the netherlands has been designed to comply with strict regulations that limit the height of the single storey structure. completed by koen olthuis of dutch architecture practice waterstudio.nl, the property utilizes additional floor space at a subterranean level, providing extra surface within the limited dimensions of the building envelope.
平面/site plan
剖面/section
剖面/section
立面/elevation
1人已打赏
居住建筑设计
返回版块28.74 万条内容 · 423 人订阅
混凝土、木、玻璃混搭的invermay 住宅images courtesy of maloney architects 一个拥有四个孩子的家庭居住于维多利亚巴拉瑞特郊外农村建于80年代的住宅中,请当地的maloney建筑师事务所来改变他们的居住条件,并且尽可能的满足他们的需求。这个倾斜的基地为他们提供了享受周边环境的机会,但他们却没有从现有的住宅中受益。这栋因弗梅住宅是一个板状混凝土、木头和提供更多空间感的玻璃的三维组合,拥有更加有效的可持续特点和与独特的地形更加融合的设计。形状的边缘,即多种材质的变化和开口,都经过了深思熟虑,使得他们共同作用,形成一个连贯的主题。
全部回复(7 )
只看楼主 我来说两句-
py1101
沙发
大面积的外墙玻璃的应用,使得整个建筑阳光起来
2015-06-01 20:33:01
luo3558
板凳
好前卫,喜欢,谢谢分享
2015-06-01 20:12:01
加载更多回复 举报
