土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 混凝土、木、玻璃混搭的invermay 住宅
发布于:2015-05-30 09:07:30 来自:建筑设计/居住建筑设计 [复制转发]
images courtesy of maloney architects
一个拥有四个孩子的家庭居住于维多利亚巴拉瑞特郊外农村建于80年代的住宅中,请当地的maloney建筑师事务所来改变他们的居住条件,并且尽可能的满足他们的需求。这个倾斜的基地为他们提供了享受周边环境的机会,但他们却没有从现有的住宅中受益。这栋因弗梅住宅是一个板状混凝土、木头和提供更多空间感的玻璃的三维组合,拥有更加有效的可持续特点和与独特的地形更加融合的设计。形状的边缘,即多种材质的变化和开口,都经过了深思熟虑,使得他们共同作用,形成一个连贯的主题。
a family with 4 children living in an 80’s home in a rural lot outside of ballarat, victoria, reached out to local practicemaloney architects to change their dwelling situation into something that more suited their needs. the sloping site affords many opportunities to enjoy the immediate and distant surroundings but was not being benefited from with their current home. the invermay house is a three dimensional composition of board-form concrete, wood, and glass that offers more space, more efficient sustainable features and a design more integrated with the unique landscape. the edges of the forms as those of the various material changes and openings are each carefully thought out to function together as a coherent motif.
a cantilevering balcony overlooks the tree canopies/悬挑的阳台可以远眺树冠。images courtesy of maloney architects
light filled living area/起居空间充满阳光。images courtesy of maloney architects
住宅的起居空间被安置在首层,拥有大的可开启的玻璃幕墙,直接开向住宅周边的庭院和茂密的森林。观景平台作为住宅中探出下坡地形的那部分,站在观景平台上可以看见远方树冠在繁华的城市之光中所产生的摇曳的阴影。住宅的楼上部分包含了线性安排的私人卧室,这样的设计使得每间卧室都与诱人的来自北侧的光线有充足的接触。在底板上的两个大的孔洞使得可操作的天窗得以往一层空间送进光来,并在垂直方向将住宅联系起来,帮助住宅自然地将室内热气排出。
the living areas of the home are situated on the ground level with large operable glass walls that spill out directly onto the yard and the dense forest around the home. as the house projects out over the descending topography, a view deck witnesses the tree canopies fading into the glowing city lights in the distance. the upstairs contains the private bedrooms arranged lineally so that each has sufficient access to the desirable northern light. two large voids in the floor plate allow operable skylights to send light to the ground level and connect the home vertically, helping to naturally expel warm air from the interior.
entry facade/入口立面。images courtesy of maloney architects
side elevation/侧立面。images courtesy of maloney architects
kitchen/厨房。images courtesy of maloney architects
dining room with large openings to the exterior/用餐区宽阔地面向室外开放。images courtesy of maloney architects
hidden desk area/隐藏的桌面。images courtesy of maloney architects
main living space/主起居室。images courtesy of maloney architects
bedroom/卧室。images courtesy of maloney architects
bathroom/浴室。images courtesy of maloney architects
floor plan / level 1 首层平面
居住建筑设计
28.74 万条内容 · 423 人订阅
欣赏边境的房子设计
© Toshiyuki Yano 这是一个建造在乡村景观和现代住宅区之间的房子。From the architect. A residence built between rural landscapes and residential streets.
