土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 生菜屋——可持续生活实验室
生菜屋——可持续生活实验室
发布于:2015-05-30 07:27:30 来自:建筑设计/公共建筑设计 [复制转发]
建筑外景
“可持续生活实验室”由清华大学艺术与科学研究中心“可持续设计研究所”与“共享社区发展中心”合作创建。项目组利用6个集装箱,构建出布局合理、空间错落有致的模块化住宅,将绿色、健康、低碳的生活理念应用到真实的生活场景中,从而带动更多人关注、理解并参与到可持续生活的实践中。
Sustainable Lifestyle Lab established by the Sustainable Design Institude of Arts and Science research center, Tsinghua University and Participatory Community Development Center. The modular house composed of six containers, which applied green, healthy, low-carbon philosophy to real life, so as to let more people to understand and participate in it.
材料
由当地土地性质决定,该住宅必须满足建造时间短、可回收、面积利用率高这些条件,因此我们采用了集装箱模块房作为原材料,它是利用集装箱本身特性由工厂制定出箱体结构、门窗、屋顶、地板、墙面等系数自行预制生产。
Material
Due to some restrictions of land ownership, the construction time must be very short, and the house should be recyclable and efficiency. So we choose container module house. The box structure, doors, windows, roofs, floors and walls can be pre-produced in the factory.
建造过程
建造过程
建造过程
建造过程
集装箱模块房现已形成完善的生产施工模式,因此前期预制和现场施工都由厂家配合完成。在厂家生产好的预制模块房运到场地后进行吊装,每个单体集装箱模块房大概需要半小时时间,集装箱模块房之间的对接处进行防水橡胶安装,最后进行楼梯和室内门的安装。随后,业主亲自完成了能耗配套设备以及绿色种植的安装。六个集装箱模块基础价18万元,改装、运输和安装费是3.8万元,共计21.8万元。
Construction process
Container module house has formed a complete production mode. The presets and the construction can be completed by the manufacturer. Each container needs about half an hour to be lifted. Then install waterproof rubber at the joint between containers. In the last, install the stairs and indoor doors. Internal design, energy equipment installation and planting are completed by the owner. The cost of the project is 218,000 yuan totally.
空间与功能
该住宅由六个集装箱模块房(6055mm*2435mm*2790mm)组成,采用“模块化设计”的思路:每个箱体内部都是标准的空间单元,承担不同功能,通过进行不同的组合模式,形成多变的功能空间。住宅内部包括三个卧室、一个储藏室、实验与展示空间和厨卫空间。作为入口的集装箱为横向布置,其他五个集装箱为纵向布置,入口处形成一个三面围合的院子。
Space and function
The house composed of six containers(6055mm*2435mm*2790mm), using ‘module design’ idea: Each box inside is a standard space unit with different functions. Different combination patterns form various function space. The house includes three bedrooms, a storage room, exhibition space, a kitchen and a bathroom . The entrance container is vertical to the other five, forming a courtyard.
系统运行图
环境友好性
集装箱模块房生产成本相对较低,可重复利用,低碳节能。同时运输便捷,且运输成本低。施工过程简单快捷,有效节省人力、物力,对周边环境噪声污染和灰尘污染小。
住宅内部采用采用生态循环圈系统设计:生活污水的收集、处理、再利用——中水系统;厨余垃圾、排泄物的收集、处理、再利用——沼气池;太阳能、风能、雨水的利用。同时采取有机种植,形成了一套完善的综合系统解决方案。
Environmental Friendliness
The production cost of container module house is low, and the container is reusable, low-carbon and energy saving. It can be transported conveniently and the transportation cost is very low. The construction is quick, easy, and resources saved, with less noise and dust pollution.
Eco-circle system design: sewage collection, treatment, re-use: the reclaimed water system; kitchen waste, excreta collection, treatment, re-use: biogas digester; solar energy, wind energy and rainwater utilization; organic farming.
屋顶种植平台
“共享社区发展中心”的推广
业主一家将在这里完成两到三年的自我实验式体验生活,不断修正功能布局以及能耗体系,对绿植进行维护,构建一套综合的系统解决方案,并探索将实验成果拓展到新型共享社区的构建中。
The Promotion of Participatory Community
The client will live here for two to three years to constantly correct the function layout and the energy system, and maintain green plants, so as to build a comprehensive solution of sustainable building, and finally explore the possibility to build the Participatory Community applied with the results of the experiment.
访谈现场
业主生活照
业主生活照
业主生活照
业主生活照
室外景观
室外景观
室外景观
餐厅
模块组合推敲
植被设置分布图
设计方案
可持续生活故事板
平面图
立面剖面图
建筑外景
项目名称:生菜屋
项目负责人:刘新
建筑师:贺鼎、王蔚、孔令晨
可持续设计团队:刘新、胡也畅、陈蔚然
业主:牛健
摄影:黎敏斐
地点:北京顺义
竣工时间:2014年7月
建筑面积:88.5平方米
Lettuce House
Project Leader: Liu Xin
Architects: He Ding, Wang Wei, Kong Lingchen
Sustainable Design Team: Liu Xin, Hu Yechang, Chen Weiran
Client: Niu Jian
Photographs: Li Minfei
Year: 2014
Area: 88.5 sqm
建筑外景
材料
Material
建造过程
建造过程
建造过程
建造过程
空间与功能
Space and function
系统运行图
环境友好性
屋顶种植平台
“共享社区发展中心”的推广
访谈现场
业主生活照
业主生活照
业主生活照
业主生活照
室外景观
室外景观
室外景观
餐厅
模块组合推敲
植被设置分布图
设计方案
可持续生活故事板
平面图
立面剖面图
建筑外景
项目名称:生菜屋
项目负责人:刘新
建筑师:贺鼎、王蔚、孔令晨
可持续设计团队:刘新、胡也畅、陈蔚然
业主:牛健
摄影:黎敏斐
地点:北京顺义
竣工时间:2014年7月
建筑面积:88.5平方米
Lettuce House
Client: Niu Jian
Year: 2014
Area: 88.5 sqm
全部回复(4 )
  • 仁者唯心
    仁者唯心 沙发
    集装箱可以叫构件。
    2016-12-24 09:51:24
  • qq_1432901710099
    这已太有意思了吧
    2016-12-22 19:11:22
公共建筑设计
51.18 万条内容 · 448 人订阅
赏析蒙斯国际会展中心
© Hufton + Crow 新会展中心是经济振兴计划的关键一环,并作为新旧之间的连接,其最初的设想是为蒙斯市建造一个新的标志性建筑。从观景台的顶部,游客可以远眺城市离市中心被联合国教科文组织列为世界遗产的17世纪的钟楼塔、由圣地亚哥•卡拉特拉瓦设计的新火车站和La Haine河。
