土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 丛林之家---大都市中宛若童话般的超级树屋
发布于:2015-03-31 10:25:31 来自:建筑设计/居住建筑设计 [复制转发]
意大利建筑师Luciano Pia在都灵完成了一座宛若童话般的超级树屋。葱葱郁郁的立体绿化让这座建筑成为都市中的“森林居所”。
Italian architect Luciano Pia has designed a house among trees in Turin. Lush green trees make this building a living forest in the urban environment.
一座新的住宅在都灵建成。其为钢架结构,树木扎根在不规则形状的阳台上,池塘与房屋基脚相交,葱郁的花园覆盖了屋顶,看起来就像一片森林。而人们也是这般感受,建筑就像是儿时梦想中时常会搭建的树屋。一座活森林建筑。
A new house has put down its roots in Turin. Its structure is in steel and it looks like a forest where trees are rooted in terraces with irregular shapes, ponds are crossed by footings and lush gardens cover the roofs. The building has been thought as a living forest, a house on the trees like the houses children dream of and sometimes build.
SCHEDA TECNICA
PLACE: VIA CHIABRERA 25, TORINO
ARCHITECTURAL PROJECT: Arch. Luciano Pia - Torino
STRUCTURAL PROJECT: Ing. Giovanni Vercelli -Torino
ENERGY PROJECT: Ing. Andrea Cagni -Torino
GREEN PROJECT: LINEEVERDI (Stefania Naretto & Chiara Otella)- Torino
COMMETTEE : GRUPPO CORAZZA, MAINA COSTRUZIONI, DE-GA S.P.A.
EXECUTOR: DE-GA S.p.A. - Torino
COMPANIES INVOLVED
• EXECUTOR: DE-GA S.p.A. - Torino
• LIGHTING: Luce per .- Torino
• SHINGLES: Sindele - Cz
• TIMBER: Tesio - Carmagnola
• COR-TEN: CCM - Pianezza
• LANDSCAPE: Vivai Reviplant & Bonifacino Angelo -Torino
LOT: 3.570 mq
GROSS FLOOR AREA: 7.500 sq. metres
TERRACES: 4.000 sq. metres
COURT GARDEN: 1.500 sq. metres
GREEN ROOFS: 1.200 sq. metres
VASE AREA: 1.200 sq. metres
WATER AREA: 150 sq. metres
EARTH ON THE DIFFERENT LEVELS: 3.000 c. metres
SHINGLES IN A LARCH WOOD: 12.000 mq = around 1.080.000 shingles
n. 140 vases with a diametre of 2,3 end 4 metres holding trees from 2 to 8 metres height
n. 40 trees in the court garden
n. 80 cor-ten trees
n. 700.000 Kilos of cor-ten material
全部回复(11 )
  • gdtop
    gdtop 沙发
    完美融合啊 谢谢楼主分享
    2015-05-26 08:41:26
  • 石大侠
    石大侠 板凳
    美人娟娟 发表于 2015-3-31 10:29 之所以有这一方案,是因为需要建造一所居住建筑不同凡响的建筑以弥补街区缺乏同质化和异质化景象的特征 …很好的资料,谢谢楼主给大家共享!
    2015-05-25 07:32:25
居住建筑设计
28.74 万条内容 · 423 人订阅
森林边缘的“梯田”别墅
一座位于瑞士中部达拉纳省森林边缘,形如三角,带有梯田层次造型的木制夏季度假小屋。项目的要求明确且具有挑战性:可以在室内外做饭,一个安静的阅读室和星空之下的一间卧室。同时还要有一个凸窗,并且屋顶从住宅正面看是梯田状。住宅总表面积大约85平方米,室内共有8间房,在8.5米高的天花板下包括两间小屋和三层阳台。这一项目在努力解决一个几近矛盾的问题:地块情况太简单,南面有风景、阳光、海洋和乳牛牧场。北面是一片密林。此外,这一地块完全平坦,缺乏树木,因为其过去是一片乳牛牧场。很显然建筑应能利用周边的风景效果,但还要处理更多的问题,使其住户能够与环境互动。
