土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 森林边缘的“梯田”别墅
森林边缘的“梯田”别墅
发布于:2015-03-31 10:21:31 来自:建筑设计/居住建筑设计 [复制转发]
一座位于瑞士中部达拉纳省森林边缘,形如三角,带有梯田层次造型的木制夏季度假小屋。
项目的要求明确且具有挑战性:可以在室内外做饭,一个安静的阅读室和星空之下的一间卧室。同时还要有一个凸窗,并且屋顶从住宅正面看是梯田状。住宅总表面积大约85平方米,室内共有8间房,在8.5米高的天花板下包括两间小屋和三层阳台。
这一项目在努力解决一个几近矛盾的问题:地块情况太简单,南面有风景、阳光、海洋和乳牛牧场。北面是一片密林。此外,这一地块完全平坦,缺乏树木,因为其过去是一片乳牛牧场。很显然建筑应能利用周边的风景效果,但还要处理更多的问题,使其住户能够与环境互动。
The requests in this project are obvious yet challenging: Cooking outdoors and indoors. A quiet reading area and a bedroom beneath the stars. All three requests has each been associated with a bay window and then superposed under a roof that turns into a terrace in front of the house. In total there are 8 rooms including two huts, three terraces, 8.5 meter ceiling on a total surface of about 85 sqm.
The project is struggling with an almost contradictory problem; the plot is almost too simple. Views, sun, sea and cow pasture lies to the south. To the north a dense forest. In addition, the plot is completely flat and lacks trees as it was former was a cow pasture. Exploiting the view is obvious but architecture should deal with more than that and let its inhabitants be able to interact with their environment.
Project name: Qvarsebo
Address:Västerbyn, Stjärnsund, Dalarna,Sweden
Architect: Leo Qvarsebo, Arkitekt MSA
Year of construction: 2011-2014
Budget: 100.000 Euro
Developer: Leo Qvarsebo, Mattias Granwald, Robobygg AB
Construction: Catherine Carrick, Konkret AB.
Carpenters:Leo, Elias, Robert, Hanna, Karl, Linnea, Mattias Granwald, Tobbe, Pappa
全部回复(14 )
  • qq_1430143180357
    ting狠好的创意
    2015-04-27 22:30:27
  • ggm7713
    ggm7713 板凳
    普通的房子,换了个外壳
    2015-04-22 14:09:22
居住建筑设计
28.74 万条内容 · 423 人订阅
三层的砖混结构中用什么样的基础地脚
三层的砖混结构中用什么样的基础地脚比较好?这样的地脚基础起什么 作用?
