土木在线论坛 \ 园林景观 \ 园林景观实景 \ 加州索诺玛亚历山大峡谷酒吧和品酒屋
加州索诺玛亚历山大峡谷酒吧和品酒屋
发布于:2014-12-01 09:56:01 来自:园林景观/园林景观实景 [复制转发]
既乡野又现代,细部设计令人惊叹,静谧之中透出如诗如画的氛围。材料搭配十分真诚、优美,同时不失冷静。——2013ASLA专业奖评语
项目展现了景观设计的潜在力量,特别突显了保护环境方面景观的主导作用,随处可见业主对本土生境、区域植物生态、水资源的保护。项目场地在20世纪20年代是个加油站,基于这一历史,设计的改造涵盖了将不透水的表面转变为注重水文和生态的品酒屋、有机花园、以有机葡萄酒和蔬菜而著称的农场。
20141127_102242_067.jpg20141127_102242_068.jpg20141127_102242_069.jpg20141127_102242_070.jpg20141127_102242_071.jpg20141127_102242_072.jpg20141127_102242_073.jpg20141127_102242_074.jpg20141127_102242_075.jpg20141127_102242_076.jpg20141127_102242_077.jpg20141127_102242_078.jpg1416974006_20140815110852150.jpg
全部回复(3 )
  • xlhxlh19750526
    路过宝地,随便进来看看、学习学习,多谢楼主;
    2018-05-22 14:32:22
  • 学习助理
    学习助理 板凳
    很不错的资料,感谢分享!
    2014-12-01 10:32:01
园林景观实景
37.75 万条内容 · 296 人订阅
Mulini伦尹海滩景观设计
Mulini Beach Bar, a beach facility with a large bar, locker rooms, showers, toilets and an information desk is located in the center of the zone. In the evening, the beach bar turns into a more intimate lounge with a cozy atmosphere by the sea. It is designed as a pavilion with a floating pergola roof – a steel structure that rests on 6 points, whose final shape was determined by an analysis of the sun movement through the summer months. The pergola, weighing 20 tons, has a span of 30m in length. It is constructed from steel sheets 8mm and 20mm thick, and has a total height of 20cm. The bar can be closed with a sliding wall that is stored inside a storage room during the day. The sliding wall is hung from the pergola construction. The plateau in front of the bar is equipped with infrastructure that allows small concerts and entertainment.
