土木在线论坛 \ 园林景观 \ 园林景观实景 \ Mulini伦尹海滩景观设计
Mulini伦尹海滩景观设计
发布于:2014-12-01 09:42:01 来自:园林景观/园林景观实景 [复制转发]
Mulini Beach Bar, a beach facility with a large bar, locker rooms, showers, toilets and an information desk is located in the center of the zone. In the evening, the beach bar turns into a more intimate lounge with a cozy atmosphere by the sea. It is designed as a pavilion with a floating pergola roof – a steel structure that rests on 6 points, whose final shape was determined by an analysis of the sun movement through the summer months. The pergola, weighing 20 tons, has a span of 30m in length. It is constructed from steel sheets 8mm and 20mm thick, and has a total height of 20cm. The bar can be closed with a sliding wall that is stored inside a storage room during the day. The sliding wall is hung from the pergola construction. The plateau in front of the bar is equipped with infrastructure that allows small concerts and entertainment.
Client: Maistra d.d.
Project management (client): Abilia d.o.o.
Project team:
Saša Begović, Marko Dabrović, Tatjana Grozdanić Begović, Silvije Novak, Nevena Kuzmanić, Tin Kavurić, Sanja Jasika
Project team collaborators: Dragana Šimić, Vibor Granić, Ivan Ćurković
Underwater construction project: Josip Prcela (Strabag-hidroinženjering)
Structural engineering – pavilion: Ivan Palijan (Palijan d.o.o.)
Electrical engineering: Tomislav Godena (Skira d.o.o.)
Plumbing and drainage: Vladimir Paun (Termotehnika Paun)
Landscape design: Luka Brnić (Vrtni Design)
Irrigation project: Damir Čizmek (In-Aqua)
Special projects – bar technology: Zoran Divjak (Dekode d.o.o.)
Structural engineering – glass roof on the pavilion pergola: Nebojša Buljan (RI ISA d.o.o.)
Signage and environmental graphics design: Lana Cavar, Narcisa Vukojević
Project name: Mulini Beach
Design: Studio 3LHD
Program: public, leisure, tourism
Status: completed
Project: 2012-2014
Construction: 2013-2014
Area (m2): 13515
Text & details: 3LHD
Photos: Joao Morgado
园林景观实景
37.75 万条内容 · 296 人订阅
常用喷泉类型分析及实景欣赏
喷泉是流动的艺术,美轮美奂的喷泉给人以无限的享受。随着社会的发展,人们生活水平不段的提高,提高了人们对景观设计的要求,在现代城市园林景观设计中,水是不可缺少的组成部分,喷泉是十分重要的景点之一,因此不管在公园设计中、还是在城市规划中、还是在小区设计中,喷泉的设计与应用是至关重要的。音乐喷泉 音乐表演喷泉是在程序控制喷泉的基础上加入了音乐控制系统,计算机通过对音频及MIDI信号的识别,进行译码和编码,最终将信号输出到控制系统,使喷泉的造型及灯光的变化与音乐保持同步,从而达到喷泉水型、灯光及色彩的变化与音乐情绪的完美结合,使喷泉表演更加生动更加富有内涵。音乐喷泉:可以根据音乐的高低起伏变化。用户可以在编辑界面编写自己喜爱的音乐程序。播放系统可以实现音乐、水、灯光气氛统一,播放同步。
