土木在线论坛 \ 建筑结构 \ 混凝土结构 \ [评测]楼板对于整体结构到底有多大影响?用数据说话
发布于:2014-05-11 00:00:11 来自:建筑结构/混凝土结构 [复制转发]
四层框架各层层高3.2m,各层x向y向均两跨,各跨4m,
柱子尺寸均400x400
x向y向梁截面均为400x400
柱梁板混凝土强度等级C30,
x向y向梁上恒载为9kN/m
楼板附加恒载为1.5kN/m2
楼板附加活荷载为2.5kN/m2
已实际考虑楼板刚度!
h=60mm
Mode 1: Value = 174.71 Freq = 2.1037 (cycles/time)
Mode 2: Value = 174.71 Freq = 2.1037 (cycles/time)
Mode 3: Value = 267.16 Freq = 2.6014 (cycles/time)
h=80mm
Mode 1: Value = 172.21 Freq = 2.0886 (cycles/time)
Mode 2: Value = 172.21 Freq = 2.0886 (cycles/time)
Mode 3: Value = 263.90 Freq = 2.5855 (cycles/time)
h=100mm
Mode 1: Value = 169.68 Freq = 2.0732 (cycles/time)
Mode 2: Value = 169.68 Freq = 2.0732 (cycles/time)
Mode 3: Value = 260.75 Freq = 2.5700 (cycles/time)
h=120mm
Mode 1: Value = 167.40 Freq = 2.0592 (cycles/time)
Mode 2: Value = 167.40 Freq = 2.0592 (cycles/time)
Mode 3: Value = 257.88 Freq = 2.5558 (cycles/time)
h=150mm
Mode 1: Value = 164.67 Freq = 2.0423 (cycles/time)
Mode 2: Value = 164.67 Freq = 2.0423 (cycles/time)
Mode 3: Value = 254.28 Freq = 2.5379 (cycles/time)
h=180mm
Mode 1: Value = 162.83 Freq = 2.0309 (cycles/time)
Mode 2: Value = 162.83 Freq = 2.0309 (cycles/time)
Mode 3: Value = 251.66 Freq = 2.5248 (cycles/time)
h=200mm
Mode 1: Value = 162.07 Freq = 2.0261 (cycles/time)
Mode 2: Value = 162.07 Freq = 2.0261 (cycles/time)
Mode 3: Value = 250.47 Freq = 2.5188 (cycles/time)
h=250mm
Mode 1: Value = 161.41 Freq = 2.0220 (cycles/time)
Mode 2: Value = 161.41 Freq = 2.0220 (cycles/time)
Mode 3: Value = 249.36 Freq = 2.5132 (cycles/time)
h=300mm
Mode 1: Value = 161.85 Freq = 2.0248 (cycles/time)
Mode 2: Value = 161.85 Freq = 2.0248 (cycles/time)
Mode 3: Value = 250.55 Freq = 2.5192 (cycles/time)
h=350mm
Mode 1: Value = 162.86 Freq = 2.0311 (cycles/time)
Mode 2: Value = 162.86 Freq = 2.0311 (cycles/time)
Mode 3: Value = 253.57 Freq = 2.5344 (cycles/time)
h=400mm
Mode 1: Value = 165.18 Freq = 2.0455 (cycles/time)
Mode 2: Value = 165.18 Freq = 2.0455 (cycles/time)
Mode 3: Value = 259.84 Freq = 2.5655 (cycles/time)
图表如下
全部回复(8 )
  • 王子涵
    王子涵 沙发
    liubin1967 发表于 2014-5-13 13:45 从楼主的结论看,一般影响极小啊可以这样子理解
    2014-05-13 15:04:13
  • 海阔天空0
    海阔天空0 板凳
    从楼主的结论看,一般影响极小啊
    2014-05-13 13:45:13
140.17 万条内容 · 2232 人订阅
如何有效率地设计
小弟搞设计已经快两年了,这两年正好是我在的这个设计院最忙的两年,来了之后就直接给整个的工程做,有点揠苗助长的感觉。有时候同时手中好几个活同时进行,经常感觉哪个也做不出去,压力好大。设计时经常是有了方案就开始结构设计了,因为经验少,不知道先做什么,而且在设计时建筑经常会改动一些东西,搞的结构经常返工,我想问的是各位在设计时,怎样才能避免返工,或者是先做哪些工作是当建筑改东西时,我们能尽量少返工的,还有当手中同时两三个活时,大家怎么安排工作的?
