土木在线论坛 \ 给排水工程 \ 市政给排水 \ 计算温度
计算温度
发布于:2007-09-23 23:44:23 来自:给排水工程/市政给排水 [复制转发]
请问“冬天和夏天江、河、湖水和污废水的计算温度”按哪本设计规范来算,
请高人指点!
市政给排水
23.69 万条内容 · 862 人订阅
污水改造和扩容
我们刚引进一项技术(IFAS),可以使现有活性污泥系统的污泥增加一倍,提高处理COD处理能力和营养物的去除(主要是氨氮),适合现有系统的改造和扩容。该技术实施简单,少维护,可在不停车条件下进行。如感兴趣,可以合作推广。 The Apex System, added to existing activated sludge systems, increases the effective Mixed Liquor Suspended Solids (MLSS) inventory of the system without increasing solids loading to the clarifier. This economical, easy-to-install system upgrades a wastewater treatment facility without increasing tankage. The Apex system requires no additional maintenance and installs with little or no disruption to plant operations.
