土木在线论坛 \ 给排水工程 \ 市政给排水 \ 污水改造和扩容
污水改造和扩容
发布于:2007-09-23 23:02:23 来自:给排水工程/市政给排水 [复制转发]
我们刚引进一项技术(IFAS),可以使现有活性污泥系统的污泥增加一倍,提高处理COD处理能力和营养物的去除(主要是氨氮),适合现有系统的改造和扩容。该技术实施简单,少维护,可在不停车条件下进行。如感兴趣,可以合作推广。
The Apex System, added to existing activated sludge systems, increases the effective Mixed Liquor Suspended Solids (MLSS) inventory of the system without increasing solids loading to the clarifier. This economical, easy-to-install system upgrades a wastewater treatment facility without increasing tankage. The Apex system requires no additional maintenance and installs with little or no disruption to plant operations.
Increased Capacity
The flexible, high-surface-area media is submerged in the activated sludge tanks to provide extensive surface area for biomass growth. The attached biomass population can increase the effective MLSS concentration by over 3000-4000 mg/l, increasing organic load capacity. This also reduces F/M ratios, improving process control and stability
Higher MLSS Without Higher Clarifier Solids Loading
Because a significant portion of the active biomass remains attached to the Apex rather than suspended in the mixed liquor, organic removal increases without overloading secondary clarifiers with higher solids loads. For activated sludge systems with clarifier solids loading problems, treatment performance can be maintained or even improved while reducing MLSS loading to the secondary clarifier.
Resistant to Organic and Hydraulic Shock Loads
An “Achilles Heel” of activated sludge technology is the potential for peak hydraulic surges to “wash out” the suspended biomass from the aeration basins. With Apex, a significant amount of biomass is fixed in place and is available to treat the incoming organic load that accompanies hydraulic surges
Enhanced Nitrification
The biomass living on the Apex media increases MCRT (Sludge Age), promoting nitrification. During cold weather and where lower compliance limits are imposed, the added biomass improves the performance of nitrifying plants, or even allows non-nitrifying plants to nitrify.
Active Media Surface
Apex media has a tensile strength in excess of 1000 lbs. per lineal foot, yet is flexible enough to move like “reeds in a stream.” This movement creates localized turbulence that constantly renews surface areas and promotes oxygen transfer.
The total surface area available for biomass attachment at startup is up to 800 sq. ft. per cubic foot of installed media module. However, dry surface area does not tell the whole story. From those 800 sq. ft. of attachment points, the biomass grows underwater in 3 dimensions, creating flexible “branches” of non-blinding active surface area that can be measured in pounds per cubic foot, while still allowing for free flow of oxygenated wastewater through the media.
Economical
By improving wastewater treatment without adding aeration tankage or clarifiers, the Apex System is a low-cost solution to upgrading activated sludge plants.
Easy to Install
The entire Apex system can be installed without dewatering the aeration basin or modifying the aeration diffusers. The custom-sized/constructed Apex modules are lowered into the aeration basin with a crane and supported by the tank walls or on legs above the tank floor.
Durable and Long-Lasting
Apex is designed for durability and long life under the harsh conditions of an activated sludge aeration tank. The Apex media uses high-strength polyester. Even if a strand is cut or broken, the fabric will not fray or unravel.
全部回复(9 )
  • xiaoyu188
    xiaoyu188 沙发
    我们现在在找合作伙伴,如果有感兴趣合作推广的,请电邮wastewater@live.cn,留下公司名称和联系电话。
    2008-01-29 22:45:29
  • xiaoyu188
    xiaoyu188 板凳
    感兴趣合作的,请留个联系电话
    2008-01-23 11:53:23
市政给排水
23.69 万条内容 · 862 人订阅
急需GB/T18477
急需GB/T18477,谁有请发信息给13937750314,多谢!
