输变电工程
返回版块11.1 万条内容 · 662 人订阅
变压题测试系统-急求信息CP Transformer test system for testing and insulation diagnosis of transformers and bushings in the field. Includes:- CPC 100 multifunctional test set hardware with supply 110/230Vac, 50/60Hz and outputs of up to 800 Aac, 2000 Vac and 400 Adc- CP TD1 unit with built-in high voltage transformer, reference capacitor and precision measurement unit- CP Tan-Delta test card software, connections and interface card to CPC 100 test unit- CP Transformer test cards- CP sequencer test card- CPC 100 standard accessories- CP TD1 connectors and cables on drums for HV injection and measurement (20m)- foldable trolley with cable drum mountings for comfortable transport of all hardware by one person in the field- TH3631 temperature and humidity measurement unit- CPC 100 user manual and Tan-Delta reference manual
只看楼主 我来说两句 抢板凳
