土木在线论坛 \ 电气工程 \ 输变电工程 \ 变压题测试系统-急求信息
变压题测试系统-急求信息
发布于:2013-01-21 11:21:21 来自:电气工程/输变电工程 [复制转发]
CP Transformer test system for testing and insulation diagnosis of transformers and bushings in the field. Includes:- CPC 100 multifunctional test set hardware with supply 110/230Vac, 50/60Hz and outputs of up to 800 Aac, 2000 Vac and 400 Adc- CP TD1 unit with built-in high voltage transformer, reference capacitor and precision measurement unit- CP Tan-Delta test card software, connections and interface card to CPC 100 test unit- CP Transformer test cards- CP sequencer test card- CPC 100 standard accessories- CP TD1 connectors and cables on drums for HV injection and measurement (20m)- foldable trolley with cable drum mountings for comfortable transport of all hardware by one person in the field- TH3631 temperature and humidity measurement unit- CPC 100 user manual and Tan-Delta reference manual
CP变压器测试系统是专门用于现场测试和诊断变压器和套管的设备,包含CPC100 多功能测试套装和输入110/230VAC 50/60HZ电,输出可达到800A AC,2000VAC和400 A DC,CP TD1单元内置高压变压器,标准电容器和高精度测量单元,CP 正切角测试软件卡,跟CPC100的通讯连接和接口卡,CP变压器测试卡,CP顺序测试卡,CPC标准附件-CP TD1连接器和相应电缆(用于高压施电和测量),可折叠带轮子,带电缆盘,要求一个人也能方便移动它,TH3631温度和湿度测试装置-CPC 100用户手册和正切角测试手册
请问国内有替代品吗?急求。
输变电工程
11.1 万条内容 · 662 人订阅
求10kV架空线路爬钉组装图
供电局要求21米电杆安装爬钉,求爬钉及其抱箍装置图
