19 固结排水试验 consolidated drained triaxial test
20 固结试验 consolidation test
21 含水量试验 water content test
22 环剪试验 ring shear test
23 黄土湿陷试验 loess collapsibility test
24 击实试验
25 界限含水量试验 Atterberg limits test
26 卡萨格兰德法 Casagrande’s method
27 颗粒分析试验 grain size analysis test
28 孔隙水压力消散试验 pore pressure dissipation test
29 快剪试验 quick direct shear test
30 快速固结试验 fast consolidation test
31 离心模型试验 centrifugal model test
32 连续加荷固结试验 continual loading test
33 慢剪试验 consolidated drained direct shear test
34 毛细管上升高度试验 capillary rise test
35 密度试验 density test
36 扭剪仪 torsion shear apparatus
37 膨胀率试验 swelling rate test
38 平面应变仪 plane strain apparatus
39 三轴伸长试验 triaxial extension test
40 三轴压缩试验 triaxial compression test
41 砂的相对密实度试验 sand relative density test
42 筛分析 sieve analysis
43 渗透试验 permeability test
44 湿化试验 slaking test
45 收缩试验 shrinkage test
46 塑限试验 plastic limit test
47 缩限试验 shrinkage limit test
48土工模型试验 geotechnical model test
49 土工织物试验 geotextile test
50 无侧限抗压强度试验 unconfined compression strength test
51 无粘性土天然坡角试验 angle of repose of cohesionless soils test
52 压密不排水三轴压缩试验 consolidated undrained triaxial compression test
53 压密排水三轴压缩试验 consolidated drained triaxial compressure test
54 压密试验 consolidation test
55 液塑限联合测定法 liquid-plastic limit combined method
56 液限试验 liquid limit test
57 应变控制式三轴压缩仪 strain control triaxial compression apparatus
58应力控制式三轴压缩仪 stress control triaxial compression apparatus
59 有机质含量试验 organic matter content test
60 真三轴仪 true triaxial apparatus
61 振动单剪试验 dynamic simple shear test
62 直剪仪 direct shear apparatus
63 直接剪切试验 direct shear test
64 直接单剪试验 direct simple shear test
65 自振柱试验 free vibration column test
66 K0固结不排水试验 K0 consolidated undrained test
67 K0固结排水试验 K0 consolidated drained test
原位测试
1 标准贯入试验 standard penetration test
2 表面波试验 surface wave test
3 超声波试验 ultrasonic wave test
4 承载比试验 Califonia Bearing Ratio Test
5 单桩横向载荷试验 lateral load test of pile
6 单桩竖向静载荷试验 static load test of pile
7 动力触探试验 dynamic penetration test
8 静力触探试验 static cone penetration test
9 静力载荷试验 plate loading test
10 跨孔试验 cross-hole test
11 块体共振试验 block resonant test
12 螺旋板载荷试验 screw plate test
13 旁压试验 pressurementer test
14 轻便触探试验 light sounding test
15 深层沉降观测 deep settlement measurement
16 十字板剪切试验 vane shear test
17 无损检测 nondestructive testing
18 下孔法试验 down-hole test
19 现场渗透试验 field permeability test
20 原位孔隙水压力量测 in situ pore water pressure measurement
21 原位试验 in-situ soil test
22 最后贯入度 final set
23. secant modulus割线模量
动力机器基础
1 比阻尼容量 specific gravity capacity
2 等效集总参数法 constant strain rate consolidation test
3 地基固有周期 natural period of soil site
4 动基床反力法 dynamic subgrade reaction method
5 动力放大因素 dynamic magnification factor
6 隔振 isolation
7 基础振动 foundation vibration
8 基础振动半空间理论 elastic half-space theory of foundation vibration
9 基础振动容许振幅 allowable amplitude of foundation vibration
10 基础自振频率 natural frequency of foundation
11 集总参数法 lumped parameter method
12 吸收系数 absorption coefficient
13 质量-弹簧-阻尼器系统 mass-spring-dushpot system
地基基础抗震
1 地基固有周期 natural period of soil site
2 地震 "earthquake, seism, temblor"
3 地震持续时间 duration of earthquake
4 地震等效均匀剪应力 equivalent even shear stress of earthquake
5 地震反应谱 earthquake response spectrum
6 地震烈度 earthquake intensity
7 地震震级 earthquake magnitude
8 地震卓越周期 seismic predominant period
9 地震最大加速度 maximum acceleration of earthquake
10 动力放大因数 dynamic magnification factor
11 对数递减率 logrithmic decrement
12 刚性系数 coefficient of rigidity
13 吸收系数 absorption coefficient
室内土工试验
1 比重试验 specific gravity test
2 变水头渗透试验 falling head permeability test
3不固结不排水试验 unconsolidated-undrained triaxial test
4 常规固结试验 routine consolidation test
5 常水头渗透试验 constant head permeability test
6 单剪仪 simple shear apparatus
7 单轴拉伸试验 uniaxial tensile test
8 等速加荷固结试验 constant loading rate consolidatin test
9等梯度固结试验 constant gradient consolidation test
10 等应变速率固结试验 equivalent lumped parameter method
11反复直剪强度试验 repeated direct shear test
12 反压饱和法 back pressure saturation method
13 高压固结试验 high pressure consolidation test
14 各向不等压固结不排水试验 consoidated anisotropically undrained test
15 各向不等压固结排水试验 consolidated anisotropically drained test
16 共振柱试验 resonant column test
17 固结不排水试验 consolidated undrained triaxial test
18固结快剪试验 consolidated quick direct shear test
全部回复(58 )
只看楼主 我来说两句20 固结试验 consolidation test
24 击实试验
原位测试
22 最后贯入度 final set
64 土工织物 "geofabric, geotextile"
65 土桩 earth pile
66 托换技术 underpinning technique
67 外掺剂 additive
68 旋喷 jet grouting
69 药液灌浆 chemical grouting
70 预浸水法 presoaking
71 预压法 preloading
72 真空预压 vacuum preloading
73 振冲法 vibroflotation method
74 振冲密实法 vibro-compaction
75 振冲碎石桩 vibro replacement stone column
76 振冲置换法 vibro-replacement
77 振密、挤密法 "vibro-densification, compacting"
78换率(复合地基) replacement ratio
79 重锤夯实法 tamping
80 桩式托换 pile underpinning
81 桩土应力比 stress ratio
动力机器基础
6 隔振 isolation
地基基础抗震
室内土工试验
