土木在线论坛 \ 建筑结构 \ 结构资料库 \ 合肥市住宅工程质量通病防治实施导则
合肥市住宅工程质量通病防治实施导则
发布于:2007-06-05 21:55:05 来自:建筑结构/结构资料库 [复制转发]
合肥市住宅工程质量通病防治实施导则,外地的\本地的都可以参考,当然外地的设计单位如果在合肥设计工程,更应该了解了!
  • boru1979
    boru1979 沙发
    确实是值得收藏的一本好书,很具有参考意义,谢谢楼主好书!收藏,下载了!
    2009-01-26 12:06:26
  • bld7657
    bld7657 板凳
    谢谢
    2007-06-06 06:30:06
结构资料库
41.29 万条内容 · 428 人订阅
谁帮我翻译一下啊!
论文简介: Abstract: Mixtures of rigid sand particles and soft fine-grained rubber particles are tested to investigate their small and large-strain responses. Mixtures are prepared with different volumetric sand fraction sf to identify the transition from a rigid to a soft granular skeleton using wave propagation, k0 loading, and triaxial testing. Deformation moduli at small, middle, and large strains do not change linearly with the volume fraction of rigid particles; instead, deformation moduli increase dramatically when the sand fraction exceeds a threshold value between sf=0.6 — 0.8 that marks the formation of a percolating network of stiff particles. The friction angle increases with the volume fraction of rigid particles.
