土木在线论坛 \ 建筑结构 \ 结构资料库 \ 谁帮我翻译一下啊!
谁帮我翻译一下啊!
发布于:2007-06-05 19:13:05 来自:建筑结构/结构资料库 [复制转发]
论文简介:
Abstract: Mixtures of rigid sand particles and soft fine-grained rubber particles are tested to investigate their small and large-strain responses. Mixtures are prepared with different volumetric sand fraction sf to identify the transition from a rigid to a soft granular skeleton using wave propagation, k0 loading, and triaxial testing. Deformation moduli at small, middle, and large strains do not change linearly with the volume fraction of rigid particles; instead, deformation moduli increase dramatically when the sand fraction exceeds a threshold value between sf=0.6 — 0.8 that marks the formation of a percolating network of stiff particles. The friction angle increases with the volume fraction of rigid particles.
附件名:2007651181042024598.zip
文件大小:48K
(升级VIP 如何赚取土木币)
  • liioo
    liioo 沙发
    看不懂,没办法啊,继续努力把
    2008-02-23 14:52:23
结构资料库
41.29 万条内容 · 428 人订阅
约束暗柱配筋《混规》与《高规》不一致
关于约束边缘暗柱纵筋的配筋范围,《混凝土结构设计规范》第11.7.15条中规定为沿墙肢长度lc和墙厚bw的乘积的1.2%、1.0%,而《高规》7.2.16条中规定的为图中阴影面积(bw、lc/2和400的最大值)的1.2%和1.0%,明显出入太大。不知各位作何理解?实际工作中如何处理?希望探讨一下。
