土木在线论坛 \ 水利工程 \ 水利工程资料库 \ 大体积混凝土温度裂缝的成因分析与控制措施
发布于:2007-05-18 20:00:18 来自:水利工程/水利工程资料库 [复制转发]
论文简介:
针对大体积混凝土的特点,讨论了大体积混凝土的概念,分析了大体积混凝土温度裂缝产生的原因及影响因素,提出了有效的控制措施。
附件名:20075181179489637503.zip
文件大小:54K
(升级VIP 如何赚取土木币)
  • zhangshen01
    zhangshen01 沙发
    为什么下载不了?为什么下载不了?为什么下载不了?为什么下载不了?为什么下载不了?为什么下载不了?为什么下载不了?为什么下载不了?为什么下载不了?
    2007-12-08 14:55:08
  • zhangshen01
    zhangshen01 板凳
    找了很久了!找了很久了!找了很久了!
    2007-12-08 14:45:08
水利工程资料库
1.37 万条内容 · 235 人订阅
Multiobjective Analysis for Suslain
论文简介: Abstract Jiuyuangou watershed is located in the hesvy and coarse sediment region of middle reaches of the yellow river.It is a experiment typical basin and exampling region of soil and water conservtion ec-construction.water resource optimum utilization is one of chiefly contents of example.based on the principle of multiobjective analysis model ,the status of water sustainable utilization was analysed and studied.the results showed that:1)under low water,water resource is enough development requirenment;2) The water environmental capacity increases,cleanse capacity strengthened;3)The social water level is general and is being improved and improved,through managing, blocking, holding, mixing(set);4) Have realized reducing flood 35.9% and sediment 69.2% benefits of reducing natural disasters well;5). Have produced the obvious effect above water of pond,could take obviously ec-environmental and travel benefits.
