土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 短肢剪力墙的地震倾覆力矩百分比大于50%,怎么调整
发布于:2012-06-08 17:38:08 来自:建筑结构/混凝土结构 [复制转发]
大家帮我看看这个应该怎么调整,
规定水平力框架柱及短肢墙地震倾覆力矩百分比(抗规)
层号 塔号 框架柱 短肢墙
21 1 X 8.53% 42.07%
Y 9.52% 39.02%
20 1 X 3.15% 66.91%
Y 3.61% 53.61%
19 1 X 1.73% 66.04%
Y 2.00% 50.07%
18 1 X 1.13% 64.11%
Y 1.31% 46.89%
17 1 X 0.81% 62.37%
Y 0.95% 44.43%
16 1 X 0.62% 61.09%
Y 0.73% 42.68%
15 1 X 0.50% 60.10%
Y 0.59% 41.32%
14 1 X 0.41% 59.26%
Y 0.49% 40.20%
13 1 X 0.34% 58.53%
Y 0.42% 39.27%
12 1 X 0.29% 57.87%
Y 0.36% 38.43%
11 1 X 0.26% 57.26%
Y 0.32% 37.63%
10 1 X 0.22% 56.68%
Y 0.28% 36.86%
9 1 X 0.20% 56.10%
Y 0.25% 36.07%
8 1 X 0.18% 55.49%
Y 0.23% 35.24%
7 1 X 0.16% 54.84%
Y 0.21% 34.37%
6 1 X 0.15% 54.08%
Y 0.19% 33.43%
5 1 X 0.13% 53.17%
Y 0.17% 32.43%
4 1 X 0.12% 52.09%
Y 0.16% 31.36%
3 1 X 0.11% 50.82%
Y 0.14% 30.33%
2 1 X 1.47% 48.96%
Y 1.09% 31.09%
1 1 X 1.69% 42.36%
Y 1.19% 23.85%
全部回复(40 )
  • xsh3555
    xsh3555 沙发
    看嵌固端即可,上面的不必理会。
    2014-10-31 09:59:31
    赞同1
  • mylond
    mylond 板凳
    pkpm中判别短肢的长度是节点到节点之间的距离,实际上墙体长度还要加半个墙厚(一字墙除外),
    所以你建模的时候输入的是1600的话,程序认定这片墙是短肢墙,实际墙厚大于1600,不是短肢墙。所以这个参数要根据你建模的情况来分析判断
    2014-10-30 16:53:30
    赞同1
140.17 万条内容 · 2232 人订阅
11G101-1的一个问题
非框架梁配筋构造中,梁底部纵筋伸入端部支座的长度是12d,但是下面说的>=0.6Lab的意思是:当12d>=0.6Lab时,不用弯锚,否则伸入支座12d,再向上弯锚15d吗???,初学者,见谅
