土木在线论坛 \ 电气工程 \ 继电保护 \ 各位前辈,我问一个关于保险丝的问题(英文)
发布于:2012-05-09 23:17:09 来自:电气工程/继电保护 [复制转发]
Calculate the time it would take to melt a steel nail (4A current fuse). The nail may be assumed to be a perfect cylinder with a diameter of 2.5mm and a length of 2cm. It should also be assumed that resistance has a linear relationship to temperature and there are no energy losses. The room temperature is 20℃. The nail has the following properties: Specific Heat Capacity 420 Jkg^-1K^-1, Density 8000kg/m^3, Resistivity 7*10^-7Ωm, Melting Point 1370℃
谢谢啦~
  • wboy8759
    wboy8759 沙发
    没什么意义。
    你是来找翻译的哦?免费为你练练手:
    “计算一枚钢钉熔化的时间(4安电流的保险丝)。假设此钢钉是一个直径2.5毫米、长2厘米的等圆柱体,其电阻与温度呈线性关系,且无能量损失,室内温度20℃。钢钉有以下性质:比热容为420 Jkg^-1K^-1,密度为8000kg/m^3,电阻率为7*10^-7Ωm,熔点为1370℃。”
    什么东东?
    2012-05-11 15:59:11
继电保护
7.33 万条内容 · 490 人订阅
可调节电容器投入不同容量是否需要调整相应保护定值
如题,电容器容量分3个档位,分别为1600Kvar,3200Kvar,4800Kvar,改变投入容量时是否需要更改保护定值,综保保护装置
