土木在线论坛 \ 暖通空调 \ 中央空调 \ 这是什么阀门
这是什么阀门
发布于:2006-09-01 15:49:01 来自:暖通空调/中央空调 [复制转发]
那位高手知道Pressure-Independent Control Valves是指什么?
相关信息:
The flow-ta-position response of valves (called valve authariry) is characterized by ASHR,4E as either quick opening,linear or equal percentage. Almost all valves used for temperature control systems are specified as equal percentage.Chapter 42 of the ASHRAE Handbook-HVAC Systems and Equipment shows how flow in different valve styles reacts to changes in position.
It also has a chart illustrating a phenomenon called authority distortion. The chart shows that any valve will only perform as advertised if the pressure differential across the valve stays constant, which almost never happens. From full load to part load, pressure differential across a control valve can vary significantly. For example, 50% valve position may equal 10%flow at design differential, or it may equal 50% flow at part load (authority distortion=0.1,see 542.9, Figure 19).
A pressure-independent control valve automatically and immediately responds to variations in pressure. It is a relatively recent innovation for hydronic applications. A perfect analogy is the variable-air-volume (VAV) box. Years ago, when VAV was in its infancy (a great idea but inconsistent space control), the invention that made VAV the smart choice for most modern buildings was making the VAV boxes pressure independent The addition of a flow ring in the box inlet meant that the box could maintain constant airflow into the space regardless of anything that was happening on the upstream side. A pressure independent control valve has a similar device at the inlet.
全部回复(4 )
  • haoqing
    haoqing 沙发
    好象是VAV上用的,请楼上说的详细点
    2006-09-03 20:24:03
  • jicke82
    jicke82 板凳
    是不是用在VAV box上的一个只靠压力自动控制的阀门?比如开利的气囊式之类的,嘿嘿,错了别笑我
    2006-09-02 22:11:02
中央空调
30.71 万条内容 · 855 人订阅
请教功率是多少?
大家好,我是个暖通外行,请教个大家个问题。我现在有套办公建筑,1000M2,层高6M。请教,要是用电的中央空调的话,用电负荷是多大?外墙有大部门是玻璃。
