土木在线论坛 \ 人才招聘 \ 学生专栏 \ 请教植物
请教植物
发布于:2011-05-20 11:24:20 来自:人才招聘/学生专栏 [复制转发]
希望大家帮帮忙
  • qiutiandetonghualb
    第一张是洒金柏,第二张是洋凤仙么?
    2011-05-27 05:30:27
  • lchcxs
    lchcxs 板凳
    第一张拍得这么不清楚,没人敢认啊!
    猜一个:修剪过度的迎春。
    第二张是什么什么凤仙。
    [ 本帖最后由 lchcxs 于 2011-5-22 19:24 编辑 ]
    2011-05-22 19:22:22
学生专栏
23.9 万条内容 · 138 人订阅
求高人给翻译一下!!小弟先谢过……
RT!如果你看到过这篇文章,那就再好不过了!我们老师让找最新的英文论文(关于模板的),但是还要我们自己翻译成中文。对于我们这些菜鸟,好难啊!……本想粘整篇文章的,想想不好意思啊……再次谢过2.2. Simply formed variable section structures -- self-forming funicular moldsFlexible fabric sheets can be easily formed into variable-section beams or trusses that follow their bending moment curves [14][15][20]. The most elegant use of fabric sheets for structural shaping of concrete members, however, is in the production of funicular shells and panels. For example, funicular compression shell and vault structures can be formed through the simple act of inverting the tension curves obrained by a loaded fabric sheet. In this instance the symetrical inversion of tension and compression geometries is perfectly matched by the symetrically oposite resistance capacities of the materials involved, i.e. the fabric in tension and the concrete in compression.
