电气资料库
返回版块70.19 万条内容 · 799 人订阅
基于最小三相异步电动机优化控制的能耗节能论文简介: Article studied asynchronous motor Phased light load regulator of the principle of energy saving voltage regulator from the theory, impact of power efficiency of three key factors when the light load: Voltage, slip and power factor, proposed power-saving conditions. Running from the energy savings of view, in theory set up the ideas of the smallest energy consumption optimization target power factor and determine formula of the optimum voltage adjust Uij by the load rate to. And to propose an automatic minimum energy optimal voltage control concept and technical realization method.
全部回复(8 )
只看楼主 我来说两句-
dianqi090101
沙发
2011-03-31 22:48:31
dianqi090101
板凳
2011-03-20 21:57:20
加载更多回复 举报
