土木在线论坛 \ 电气工程 \ 电气资料库 \ 基于最小三相异步电动机优化控制的能耗节能
发布于:2011-02-15 19:09:15 来自:电气工程/电气资料库 [复制转发]
论文简介:
Article studied asynchronous motor Phased light load regulator of the principle of energy saving voltage regulator from the theory, impact of power efficiency of three key factors when the light load: Voltage, slip and power factor, proposed power-saving conditions. Running from the energy savings of view, in theory set up the ideas of the smallest energy consumption optimization target power factor and determine formula of the optimum voltage adjust Uij by the load rate to. And to propose an automatic minimum energy optimal voltage control concept and technical realization method.
附件名:20112151297768166864.zip
文件大小:110K
(升级VIP 如何赚取土木币)
电气资料库
70.19 万条内容 · 799 人订阅
出入口控制系统工程设计规范(含条文说明)GB50396-2007
