土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 地铁高架车站
地铁高架车站
发布于:2010-12-15 15:04:15 来自:建筑结构/混凝土结构 [复制转发]
地铁高架车站
全部回复(4 )
  • shdwl5945
    shdwl5945 沙发
    学习一下sap的高级应用
    2014-10-10 09:46:10
  • wang_wei68259700
    应该是一系列的图纸吧 不会仅是剖面图啊!
    2012-03-02 15:07:02
140.17 万条内容 · 2228 人订阅
钢-混组合框架抗震性能研究进展
论文简介: Composite reinforced concrete and steel moment frame structures are comprised of reinforced concrete(RC) columns and steel (S) beams – the so-called composite RCS frames. Extensive research over the past several decades suggests that such systems are particularly well proper and economic for use in mid- to high-rise buildings in low to moderate seismic risk regions and low to mid-rise buildings in moderate to high seismic risk regions. This paper reviews the state-of-the-art in testing, finite-element analysis and design of composite RCS systems. Development of guidelines and recommendations of RCS beam–column connections and RCS moment frames are presented and a future research on composite RCS systems is provided.
