土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 钢-混组合框架抗震性能研究进展
钢-混组合框架抗震性能研究进展
发布于:2010-12-15 14:26:15 来自:建筑结构/混凝土结构 [复制转发]
论文简介:
Composite reinforced concrete and steel moment frame structures are comprised of reinforced concrete(RC) columns and steel (S) beams – the so-called composite RCS frames. Extensive research over the past several decades suggests that such systems are particularly well proper and economic for use in mid- to high-rise buildings in low to moderate seismic risk regions and low to mid-rise buildings in moderate to high seismic risk regions. This paper reviews the state-of-the-art in testing, finite-element analysis and design of composite RCS systems. Development of guidelines and recommendations of RCS beam–column connections and RCS moment frames are presented and a future research on composite RCS systems is provided.
附件名:201012151292394398475.zip
文件大小:2462K
(升级VIP 如何赚取土木币)
140.17 万条内容 · 2228 人订阅
请教:关于剪力墙构造边缘构件问题
有一框架-剪力墙为结构,有一L形剪力墙,转角处有一框架柱,但尺寸不满足端柱的要求(即小于两倍的墙宽),此时需不需要在L形转角的位置按照构造边缘构件的要求设置L形的构造边缘构件呢?还是只要框架柱配足钢筋就行?请有经验的朋友指示,谢谢。
