给排水资料库
返回版块22.46 万条内容 · 568 人订阅
请教翻译~~~~~Nonlinear programming provides a framework for this inverse problem, which is formulated as a least squares minimization subject to the differential and algebraic constraints of the network water quality model. Unknown time-dependent injection terms are introduced at every network node, and the solution of the nonlinear program provides an estimate of the time and location of contamination sources. The network water quality model contains partial differential pipe equations that are a function of both time and displacement. A naive discretization of this system in
全部回复(5 )
只看楼主 我来说两句-
zyf080404
沙发
很有用,谢谢!楼主辛苦了
2009-08-18 16:21:18
hexiaomingsky
板凳
当地建筑门户网站有,在别的地方不一定一样啊!!!!用的兄弟门注意了啊
2008-01-05 18:01:05
加载更多回复 举报
