土木在线论坛 \ 给排水工程 \ 给排水资料库 \ 请教翻译~~~~~
请教翻译~~~~~
发布于:2006-02-28 15:04:28 来自:给排水工程/给排水资料库 [复制转发]
Nonlinear programming provides a framework for this inverse problem, which is formulated as a least squares minimization subject to the differential and algebraic constraints of the network water quality model. Unknown time-dependent injection terms are introduced at every network node, and the solution of the nonlinear program provides an estimate of the time and location of contamination sources. The network water quality model contains partial differential pipe equations that are a function of both time and displacement. A naive discretization of this system in
time and space produces a large-scale, nonlinear math programming problem that is unreasonably large for current optimization tools. To overcome this difficulty, an origin tracking algorithm based on the Lagrangian technique of Liou and Kroon is
developed to reformulate the partial differential pipe expressions into a set of algebraic time delay constraints, removing the need to spatially discretize along the length of the pipes.
给排水资料库
22.46 万条内容 · 568 人订阅
常用缩略语
常用缩略语 ACA 美中农业合作协定AIC 工商局APEC 亚太经济合作组织AQSIQ 国家质量监督检验检疫总局CAAC 民航总局CBRC 中国银行业监督管理委员会CCC 中国强制认证CCEE 中国电工产品认证CCIB 中国商品检验局CICC 中国国际金融有限公司CIETAC 中国国际经济贸易仲裁委员会CIF 到岸价(成本、保险费和运费)CIRC 中国保险监督管理委员会
