发布于:2010-12-09 17:43:09
来自:建筑结构/武汉老庄结构院
[复制转发]
在使用PKPM画结构平面图时,发现一块大板的挠度居然轻轻松松过了,而我之前使用摩根演算的时候,需要加大板底配筋才能算过。
因此我分别对比了PKPM和摩根的计算书,发现一个大不同的地方:
PKPM:
Pkpm:
二、计算结果:
Mx =(0.06273+0.00790/5)*(1.20* 5.2+1.40* 1.0)* 4.8^2 = 11.32kN?M
考虑活载不利布置跨中X向应增加的弯矩:
Mxa =(0.09163+0.01980/5)*(1.4* 1.0)* 4.8^2 = 3.08kN?M
Mx= 11.32 + 3.08 = 14.40kN?M
Asx= 317.52mm2,实配φ 8@150 (As = 335.mm2)
ρmin = 0.200% , ρ = 0.223%
My =(0.00790+0.06273/5)*(1.20* 5.2+1.40* 1.0)* 4.8^2= 3.60kN?M
考虑活载不利布置跨中Y向应增加的弯矩:
Mya =(0.01980+0.09163/5)*(1.4* 1.0)* 4.8^2 = 1.23kN?M
My= 3.60 + 1.23 = 4.83kN?M
Asy= 300.00mm2,实配φ 8@160 (As = 314.mm2)
ρmin = 0.200% , ρ = 0.209%
Mx' =0.11953*(1.20* 5.2+1.40* 2.0)* 4.8^2 = 24.90kN?M
Asx'= 562.55mm2,实配φ10@125 (As = 628.mm2,可能与邻跨有关系)
ρmin = 0.200% , ρ = 0.419%
三、跨中挠度验算:
Mk -------- 按荷载效应的标准组合计算的弯矩值
Mq -------- 按荷载效应的准永久组合计算的弯矩值
(1)、挠度和裂缝验算参数:
Mk =(0.00790+0.06273/5)*(1.0* 5.2+1.0* 2.0 )* 4.8^2 = 3.39kN?M
Mq =(0.00790+0.06273/5)*(1.0* 5.2+0.5* 2.0 )* 4.8^2 = 2.92kN?M
Es = 200000.N/mm2 Ec = 29791.N/mm2
Ftk = 2.01N/mm2 Fy = 360.N/mm2
摩根:
1.2 弯矩计算结果
1.2.1 平行于 Lx 方向的跨中弯矩 Mx
Mxgk1 = (0.06273+0.2*0.0079)*5.2*4.8^2 = 7.71kN?m
Mxqk1 = (0.06273+0.2*0.0079)*2*4.8^2 = 2.96kN?m
Mx = Max{Mx(L), Mx(D)} = Max{13.4, 13.31} = 13.40kN?m
Mxk = 10.67kN?m Mxq = 8.89kN?m
Asx = 295mm ρ = 0.23% 8@170 (As = 296) ωmax = 0.236mm
1.2.2 平行于 Ly 方向的跨中弯矩 My
Mygk1 = (0.0079+0.2*0.06273)*5.2*4.8^2 = 2.45kN?m
Myqk1 = (0.0079+0.2*0.06273)*2*4.8^2 = 0.94kN?m
My = Max{My(L), My(D)} = Max{4.26, 4.23} = 4.26kN?m
Myk = 3.39kN?m Myq = 2.83kN?m
Asy = 100mm ρ = 0.08% ρmin = 0.18% Asy* = 269mm
8@180 (As = 279) ωmax = 0.028mm
1.2.3 沿 Lx 方向的支座弯矩 Mx'
Mx'gk1 = -0.11953*5.2*4.8^2 = -14.32kN?m
Mx'qk1 = -0.11953*2*4.8^2 = -5.51kN?m
Mx' = Max{Mx'(L), Mx'(D)} = Max{-24.9, -24.73} = -24.90kN?m
Mx'k = -19.83kN?m Mx'q = -16.52kN?m
Asx' = 563mm ρ = 0.43% 12@200 (As = 565)
ωmax = 0.297mm
1.3 跨中挠度验算
1.3.1 挠度验算参数
按《建筑结构静力计算手册》表 4-2,挠度系数 κ = 0.00496(1/M)
Mk = 10.67kN?m Mq = 8.89kN?m
通过对比文中红色的地方,我发现PKPM取的是弯矩小的方向,而摩根取的是弯矩大的方向然后查阅混规8.2.2条:
Mk--按荷载效应的标准组合计算的弯矩,取计算区段内的最大弯矩值;
Mq--按荷载效应的准永久组合计算的弯矩,取计算区段内的最大弯矩值;
Bs--荷载效应的标准组合作用下受弯构件的短期刚度,按本规范第8.2.3条的公式计算;
θ--考虑荷载长期作用对挠度增大的影响系数,按本规范第8.2.5条取用。
于是觉得摩根的准确!
希望大家探讨下对错~~谢谢
全部回复(9 )
只看楼主 我来说两句-
lunhui211
沙发
楼主的确比较心细,可以这么考虑:使用PKPM出楼板的计算书,用摩根复核大板的配筋、挠度、裂缝,这样就更加的方便了,呵呵。
2010-12-10 12:29:10
赞同1
chinalxb
板凳
2020-06-12 18:04:12
加载更多回复 举报
"我发现PKPM取的是弯矩小的方向,而摩根取的是弯矩大的方向" 楼主这句话的意思是PKPM取的是跨度长的方向,而摩根取的是跨度短的方向。推演了半天,其实挠度的计算公式很简单。而我们的公式都是简化的,实际情况不是我们假定的那么简单,混凝土板与梁之间的约束既不是我们认为的铰接也不是绝对的刚接,无论按哪个方向计算,都不要忽略了变形协调。我们是搞工程的,不是搞航天和导弹的,只要我们得到一个合理的结果就好。
