土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 纪念一代大师,看看什么才是真正的建筑结构+结构建筑
发布于:2006-01-12 10:28:12 来自:建筑结构/混凝土结构 [复制转发]
Pier Luigi Nervi奈尔维
(b. Sondrio, Lombardy 1891; d. Rome, Italy 1979)
Pier Nervi was born in Sondrio, Lombardy in 1891. He began work as an engineer and contractor in 1923, after training as an engineer at Bologna University. In the 1940s he developed ideas for a reinforced concrete which allowed him to create structures of "strength, simplicity and grace". His services as an engineering consultant were highly sought as a result of his experimentation with structural concrete.
记住下边的这段:
Nervi believed that architecture and engineering were two connected parts of a whole. To produce good buildings, he felt that a knowledge of materials, nature and construction were essential to understanding architecture. His work as a theorist attracted a wide following.
Through his designs, Nervi successfully made reinforced concrete the main structural material of the day. He was awarded Gold Medals by the RIBA, the AIA and the Academi d’Architecture. In the years 1946-61 he was a professor of engineering at Rome University.
Nervi died in Rome in 1979.
附图1
全部回复(17 )
  • 张工0503
    张工0503 沙发
    一个优秀的建筑师从某种意义上说就应该是一个优秀的结构工程师,很多优秀的工程就是遵循基本的力学规律来塑造建筑美,这样的工程即美观又安全,造价又省。而一些所谓的建筑师,完全脱离力学去塑造建筑的艺术美(这也是结构工程师最头疼的,呵呵),虽然一些工程也名留青史,但不能说得上是成功的作品。最经典的正面教材是巴黎的埃菲尔铁塔,最经典的反面教材是悉尼歌剧院。
    2006-04-05 10:45:05
  • jyu
    jyu 板凳
    我也是一个要搞毕业设计的土木学生,谢谢您!~真是大家都是流着中华民族的血,一方有难,百方支援!!谢谢
    2006-04-02 18:18:02
140.17 万条内容 · 2232 人订阅
转换结构侧向刚度比计算的问题
对于底部大空间上部为框剪的转换结构,其侧向刚度比应满足高规附录E的要求。但这里有个问题,就是上部结构的实际刚度受填充墙的影响,而底层填充墙少。软件里的周期折减系数并不用来计算刚度,而是用来计算地震影响系数。而软件又无法针对不同的楼层设置不同的折减系数。所以,对于转换结构,软件计算出来的侧向刚度比实际是不符合实际的。那对于这点大家一般怎么处理呢?
