土木在线论坛 \ 环保工程 \ 水处理 \ 我有二手污水处理设备, 有没有人要
我有二手污水处理设备, 有没有人要
发布于:2010-06-30 15:25:30 来自:环保工程/水处理 [复制转发]
我有二手污水处理设备:
(1) 2 台 HV-Turbo 鼓风机
(2)10台 Donkin 鼓风机
(3) 3台 Bird Humboldt 离心机
污水厂关闭, 设备闲置。不知有没有人要。
BR/Jiande
彭建德 博士
Prosper Recycler Pte Ltd
Singapore
+6597885786
jiandepeng@sohu.com
  • pjd158
    pjd158 沙发
    (1)设备保养不错,带有备件。我可为感兴趣者提供详细资料。
    (2)是的。设备在新加坡。运输应该没有问题。
    以下是有关该工厂的情况:
    http://wikimapia.org/10018554/Kim-Chuan-Water-Reclamation-Plant-Closed
    Kim Chuan Water Reclamation Plant (Closed) (Singapore)
    (edit info)
    SINGAPORE'S oldest water reclamation plant Kim Chuan closed its door in February, 2008, as used water is being channeled to the deep tunnel sewerage system.
    The Kim Chuan plant is the first to be phased out, said Public Utilities Board (PUB), the national water agency. Others to be phased out are the reclamation plants at Bedok and Seletar.
    The Kim Chuan plant started operations in 1948. Over the last 60 years, it has undergone several phases of expansion and development. Its capacity for used water treatment has increased 20 times from an initial 14,000 cubic metres per day in 1948 to 282,000 cubic metres per day today.
    The plant served the central and eastern parts of Singapore including new towns such as Toa Payoh, Bishan, Whampoa, Kallang, Serangoon, Hougang and Eunos.
    The phasing out of the conventional water reclamation plants is part of Singapore's Public Utilities Board's long-term used water management plans. The Deep Tunnel Sewerage System is a robust and sustainable used water system that will bring us many benefits such as land and manpower savings.
    2010-07-02 01:03:02
  • shang_tingting
    楼主吧,一些设备参数提出来,有需要的就可以直接和你联系啦,另外我有个小问题,设备现在在新加坡?
    2010-07-01 13:09:01
水处理
43.08 万条内容 · 1503 人订阅
我需要实验室废液处理设备
各位大师您好: 实验室里的有机溶液 无机溶液 的处理, 处理量最多每天不超过300升 最少每天50升。 我希望各位大师能给我们做个小型的设备,体积不要大,工艺 絮凝 吸附 中和 消毒 膜片 超滤 代价无所谓, 要求 ,达到国家排放标准,QQ857701408
