土木在线论坛 \ 施工技术 \ 工地图片 \ 谁见过这种做法的柱底没有?
谁见过这种做法的柱底没有?
发布于:2010-05-01 18:31:01 来自:施工技术/工地图片 [复制转发]
这是一个食堂的钢结构单厂,这种做法的剪力键,谁同见过?同时短柱也是偏心的.螺栓也没有垫块,大家看看这样可行吗?
[ 本帖最后由 fjons 于 2010-7-3 23:18 编辑 ]
全部回复(25 )
  • kayllen
    kayllen 沙发
    这也太夸张了吧,抗剪槽都没留,就是2次灌浆料也着不住啊,那材料够贵的。是成都吗哪儿的,就是这种,安装钢柱和短柱距离太高,某天一阵大风,排架倒了一大片。
    2010-11-26 16:42:26
  • zyj_19890923
    zyj_19890923 板凳
    有待进一步改进啊
    2010-11-25 20:52:25
工地图片
50.2 万条内容 · 383 人订阅
架空线路工程人员注意了,非同寻常的图片
为什么这只鹿会挂在架空线路上?看英文说明:Power MooseThe following picture was taken after new power cables were being strung along the ground at great lengths. An unsuspecting moose, grazing on top of the lines, got his antlers stuck on the cables when, miles away, the crew began pulling the lines into position with their line machinery. As the cables went up, so went the moose. But, after noticing extra tension in the lines, the crew stopped to find the problem. When they saw the moose, he was still alive and the crew lowered him to the ground.
