土木在线论坛 \ 施工技术 \ 工地图片 \ 架空线路工程人员注意了,非同寻常的图片
架空线路工程人员注意了,非同寻常的图片
发布于:2010-05-01 08:16:01 来自:施工技术/工地图片 [复制转发]
为什么这只鹿会挂在架空线路上?
看英文说明:
Power Moose
The following picture was taken after new power cables were being strung along the ground at great lengths. An unsuspecting moose, grazing on top of the lines, got his antlers stuck on the cables when, miles away, the crew began pulling the lines into position with their line machinery. As the cables went up, so went the moose. But, after noticing extra tension in the lines, the crew stopped to find the problem. When they saw the moose, he was still alive and the crew lowered him to the ground.
我的答案: 也许是施工过程中,鹿角缠在电线上,而放线人员还在施工哦。
你的答案是什么呢?
全部回复(12 )
  • 米克
    米克 沙发
    2011-06-16 13:03:16
  • trublemaker
    trublemaker 板凳
    一只求上进的小鹿。
    2011-06-16 12:06:16
工地图片
50.2 万条内容 · 383 人订阅
大金120匹压缩机电机维修
大金120匹压缩机电机
